Results 1 to 10 of 10
Thread: emissions question
    Senior Member SUPERDUTY's Avatar
    Jan 2008
    181
    emissions question
    someone told me that my truck weighs enough not to have emissions on it. Is there a weight where they stop giving emissions tests?
    2007 Hummer H2
    2006 Hummer H1 ALPHA
    Ford guy turned GM
    Jan 2008
    Jefferson
    4,674
    What county are you in? If the truck weighs more then 8800 then u need the sniffer test (old machine) to pass. I had the same problem when I tried to pass a f250. It won't pass on obd 2 machine.
    Oct 2007
    Baldwin
    259
    If you are in an emissions county, you truck won't get emissions IF: the vehicle's gross weight is over 9000 pounds or it is diesel. With a superduty, you either get a sniffer if it is less than 9000 lbs, or nothing if it is above.
    2012 Husqvarna TE 449
    2007 BMW E92 328xi
    2003 F250 Superduty
    2004 SV650
    Jan 2008
    181
    the truck empty doesn't weigh 9000 but the gvw is 9000
    2007 Hummer H2
    Ford guy turned GM
    Jan 2008
    181
    i am in allegheny also
    2007 Hummer H2
    Ford guy turned GM
    Jan 2008
    Jefferson
    4,674
    youll need the sniffer test.
    Oct 2007
    creighton pa
    260
    if truck is registered at 9000+ gvw doesnt need emission sticker in any county.
    shaler,pa
    1,010
    Quote Originally Posted by casper gt View Post
    89 Mustang (stock) DD
    82 Trans Am (not stock)
    98 Audi A4 (not so hurting)
    Oct 2007
    Baldwin
    259
    Registered weight means nothing, the GVWR on the door sticker is what matters. 9000 lbs or less must get an emissions. 9001 lbs and up get nothing.
    If the GVWR on the sticker saya 9000 lbs and you live in Allegheny county you should get a sniffer test given the truck is gasoline powered.
    2007 BMW E92 328xi
    2003 F250 Superduty
    2004 SV650
    Jan 2008
    181
    lol figures o well maybe ill just trade it in. been looking at a caddy cts v anyway
    2007 Hummer H2
    Ford guy turned GM
  1. Emissions Hookup ?
    By SlowSix in forum The Bar
    Last Post: 04-24-2013, 09:34 PM
  2. Longtubes and emissions?
    By SlowSix in forum General Tech
    Last Post: 05-01-2011, 12:54 PM
  3. CA Emissions???
    Last Post: 09-03-2009, 09:35 AM
  4. Emissions Failure
    Last Post: 05-20-2009, 05:23 PM
  5. Emissions
    By MellowYellow03 in forum The Bar
    Last Post: 09-21-2006, 11:56 PM
