Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 43
Thread: Can I get a Freaking Break!!!!!!
  1. #21
    Those look like stock replacement pushrods. Looks like there allready showing wear. I would make sure the length is right and order hardened ones.
  2. #22
    Marine Eng. Officer ArmyWarrant's Avatar
    Fort Eustis, VA
    525
    OK I am gonna order a pushrod length checker and get some hardened pushrods.
    90 GT stock needing some minor work, traded my 87 Vert to my bro for it.
    2004 RAM 1500 Quad Cab Hemi DD Gonna be up for sale soon
    86 Notch New Project
  3. #23
    Old Fart Racer altoona's Avatar
    Jun 2008
    28
    Ah, not centered side to side, I thought you meant front to back. Disregard my previous post!
    From the description it looks like that's a stock non-hardened push rod. I'd call Summit and ask, they could probably tell you.
    OFR - old fart racing
    We aren't the fastest car at the track, but we might be having the most fun!
    Best so far - 11.957 @ 117.09 on 10-18-08
  4. #24
    Fort Eustis, VA
    525
    Quote Originally Posted by altoona View Post
    Well no need to disregard your previous post. I just didn't understand what you were saying I guess. I talked to Tim today and he straightened me out on the pushrod length checker. The pushrods that were in the car were 3/8" to short and my valve train geometry was way off. I am willing to bet the roller tip was barely catching the valve stem at full lift. I got it now though, I need to order some 6 5/8" hardened push rods and get the springs checked to make sure they have the proper seat pressure. I also will definitely be pulling the heads now and checking PTV clearance with the new push rods. Hopefully I will see no valve damage and PTV will be good to go.
    Thanks Alot to Tim, you have been a huge help!
  5. #25
    Fort Eustis, VA
    525
    OK I've redone the valve geometry again with the adjustable push rod and I've found that I can use a pushrod that is 6 3/4" in length measured with a tape measure, I will use a digital caliper tomorrow at work to get exact measurements. I redid the geometry in better light so I could better tell the center of the valve stem and realized the previous measurement was a lil off. I also got my springs checked at my machine shop and they have the following numbers
    installed height seat pressure valve open seat pressure valve closed
    1.800" 340 130
    1.850" 320 115
    Are these springs ok for a z cam? Also I am gonna go with these pushrods so I can do it on the cheap so I can get my car running so I can enjoy it a lil this summer. I will be disassembling the motor this winter and reringing and rebearing the whole engine so I will get better pushrods then.
    http://store.summitracing.com/egnsea...115+4294778917
  6. #26
    the installed height of 1.800 is pretty good pressure for the z cam but you should check bind height of that spring because i thin kthe z cam is like .544 lift...
  7. #27
    Fort Eustis, VA
    525
    .552 lift with 1.6 rockers. How do I check bind height? I've rotated the engine to full lift with .040 feelers gauge between the coils of the spring and they had slight drag on the feelers gauge. Is this good or is there something else I need to check.
  8. #28
    that method is acceptable..
  9. #29
    Fort Eustis, VA
    525
    OK Thanks Tim I measured with a 6-7 mic today and the actual measurement is 6.765. Would the 6.805 be okay to use? Only .040 difference, don't know if this will be enough to make a diff or not.
  10. #30
    Fort Eustis, VA
    525
    well I ordered some trick flow 6.75" pushrods from summit today. My DD cavalier looks like it is going to need a head so I gotta get the stang running for the time being. The head alone for the cavalier is gonna be 250 plus the gasket kit is 210. That together is more than I paid for the whole dang car.
  11. #31
    Selinsgrove, PA
    526
    damn bro, youve got my kind of luck :(
    good luck with getting both back on the road!!
    Fox/n.
  12. #32
    Fort Eustis, VA
    525
    Well got the pushrods and installing them shortly, hopefully the stang will be purring again soon. Just gotta refresh my memory on setting the rockers. How can I pump the lifters up with oil without turning the car over and running it?
  13. #33
    Fort Eustis, VA
    525
    IT IS ALIVE!!!!!!!! Put the new pushrods in used a oil pump priming tool to pump the lifters up and it fired right up after get the fuel system primed after sitting for 3 months. I have a couple rockers I need to redo but other than that it should be mobile again tomorrow
  14. #34
    out in the woods
    4,948
    nice, glad to hear everythings finally working out for ya.
    2003 polaris predator 500
    (wanna ride,just pm me!!!)
  15. #35
    Fort Eustis, VA
    525
    Been driving it for a couple days now and its running ok. I need to make some adjustments to the timing and might be having issues with the msd pro billet dizzy not advancing like its supposed to. It was originally locked out but I reinstalled an advance kit and have the lightest springs and I believe they are the 20* of advance bushings in it but I am not seeing the advance happening. When should the timing advance, at what RPM?
  16. #36
    Fort Eustis, VA
    525
    I checked the rockers tonight and found what I think are serious wear marks on the push rods. It seems they are making contact with the rockers at full lift. They are hitting on the back side of the rockers. I have absolutely no freaking luck! I think its punishment for making the jump from Chevy to Ford. I had a 1982 monte carlo prior to my first stang and decided to get the stang when I couldn't pass up the deal. I've always wanted to fox body and now they are giving me nothing but headaches. GRRRRRRRRRR
  17. #37
    out in the woods
    4,948
    Quote Originally Posted by ArmyWarrant View Post
    as long as you own one thats all your gonna have... go back to chevy!!!
    you'll be so much happier
  18. #38
    Fort Eustis, VA
    525
    LOL, if I could at this point I might. Just don't have the funds to do it. I like the car but I mean it seems everytime I get a car I inherit someone else's problems. I am thinking I will sell the shortblock and then park it behind my house until I can finish up the engine bay clean up and find a 351 for it.
  19. #39
    out in the woods
    4,948
    yea, that usually is the issue when as you said "i couldnt pass up the deal" cheap car usually means something wrong with it and past owner doesnt wanna mess with it.
    i almost got chris (fknfst) changed back over to chevy, workin on it,lol...
  20. #40
    Fort Eustis, VA
    525
    Quote Originally Posted by INSANELY CRAZY View Post
    Well the thing is with the changeover the car I got was my first one. I knew this one wasn't perfect but ever since I got it I have found out that the PO had it assembled by some shadetree mechanic and nothing was done right. So I wouldn't doubt if the dizzy or the MSD box are screwed. It would just be icing on the cake. I can't really complain to much I only have about 1400 in this one right now, the first one I had over 9500 in and it went to shit due to some shi@#ty procomp alum heads and a faulty camshaft. I am gonna try getting a regular vacuum advance dizzy and taking the rockers off and clearancing them for the pushrods. I just need info on how to run a non efi dizzy in a car that was originally EFI and doesn't have the harness that had the wires for the EFI dizzy anymore. Got any ideas?
  1. trailer hitch and power break ?
    By k7cobra in forum Other Ford
    Last Post: 04-03-2012, 08:19 PM
  2. Lunch Break?
    By map351 in forum Pictures & Videos
    Last Post: 08-31-2011, 02:07 PM
  3. Is this guy freaking serious???
    By 92306gt in forum Ford Vehicles
    Last Post: 12-09-2010, 03:18 PM
  4. Anybody here ever break their femur???
    By no1sirbutler in forum The Bar
    Last Post: 05-30-2008, 12:58 AM
  5. Spring Break 08'
    By Rio94gt in forum The Bar
    Last Post: 03-26-2008, 09:55 AM
