Results 1 to 1 of 1
Thread: 351W Motor (Air Filter to Oil Pan)
    Member DING's Avatar
    New Bern, NC
    324
    Package deal comes with everything listed below. Would rather not seperate.
    351 Windsor motor .030 over bore
    Steel heads (large spark plug) with port work
    9.5-1 Compression
    Harden 1.94 I - 1.60 E valves (stainless)
    Comp Cams 553/536 lift 290/295 adv. duration
    Hydraulic Lifters
    Comp Cams Roller Rockers
    Keith Black Pistons
    Clevitte Bearings
    Mellen High Vol. Oil Pump
    Ford Motorsport Oil Pan W/Pickup
    Double Roller Timing Set
    CAT SFI Harmonic Balancer
    Steel Crank
    Steel Rods
    Edelbrock RPM Performer Intake
    Felpro Gaskets
    ARP Fasteners
    HP Motorsports Solid Motor Mounts
    Barry Grant Speed Demon 750DP Carb
    Moroso 1" Carb Spacer
    Ford Racing Valve Covers
    K&N Air Filter 14"x3"
    K&N Oil Breather
    MSD Billet Distributer
    MSD 6AL Ignition Box
    Taylor Spark Plug Wires W/Separaters
    Barry Grant 280 GPH Fuel Pump
    Accufab Custom Headers 1-5/8" to 3" collector
    Only Royal Purple Oil Used
    Motor ran mid 11's on pump gas
    Basically everything you would need to drop it in your car and go. I have never had a problem with this motor.
    It is in PERFECT working order. You will not be disappointed.
    Great Street or Strip motor
    Asking $3500
    Hank
  1. Fox 351W solid mounts and oil pan
    By Dan B. in forum Ford Vehicles
    Last Post: 01-13-2013, 08:15 AM
  2. Free: 03/04 cobra K&N filter & oil filter
    By KBCobra in forum Ford Vehicles
    Last Post: 08-30-2010, 01:29 PM
  3. Replies: 7
    Last Post: 05-01-2010, 08:59 PM
  4. 7qt 351w Oil Pan
    By badstanglx in forum Ford Parts
    Last Post: 09-28-2007, 11:31 PM
  5. 79-93 fox 351w moroso oil pan 4-sale
    By Rodeheaver's in forum Ford Vehicles
    Last Post: 09-05-2006, 10:25 AM
