1967 Mercury Marquis – 2 door
Posting for a buddy. Car is located 30 min northwest of Columbus, OH. (3.5 hours from PGH)
Body: Original Steel, some previous rust repair in front of rear wheels, has some rust bubbles under the vinyl roof, overall I would classify it as a 5-footer
Frame, suspension, and brakes are very solid
Interior is black and very nice…bench seat
Engine, Exhuast, and Ignition:
416ci FE
Reworked stock crank and rods with forged pistons (10:1 comp)
Factory Iron Cobra Jet heads, ported
Aftermarket HD rocker shaft mounts with HD end supports
228/236 deg comp cam with .556” lift and matching valve springs
Edelbrock Performer RPM Intake Manifold
Edelbrock 750 cfm carb and tuning kit
Pertronix Pointless Ignition
Holley Annihilator Digital Ignition w/ soft touch adjustable rev limiter
Hooker Super Comp Long Tube Headers
2.5” dual exhaust with the baddest sounding mufflers you’ve ever heard.
Tranny and Rearend:
New TCI C6 with Ford Kickdown
New 4.11 Richmond gears, fresh 31 spline trac-loc
Rolling stock consists of OEM Bullitt wheels and 75% new rubber
Stock cool equipment that still works:
High beam dimmer
6 way power split bench seat (driver and passenger side power)
Stock cool non functioning equipment: but could be fixed easily
Power Locks (vacuum)
Remote Trunk Release (vacuum)
Car has run 14.3 @ 98mph on street tires which isn’t too bad for a 4000lb car and a stock stall convertor.
As you can imagine this car gets tons of looks and compliments every time he takes it out. Only reason he is selling is because he needs the garage space to redo his 66 F250. The starter just went out in the car (remanned unit, needs new bendix) and that was the last straw. He has a good working original starter to go with the car. It will start, run, and drive anywhere you want it…
Price is $4,800 OBO (there is more than that in the engine and tranny)
PM me for his phone number if you are serious. If you like looking at pictures of other people’s cars for sale and you’re not looking to buy, don’t pm me.
