not sure of what the first two things exactly are for....im pretty sure they are for emissions/smog pump, which in that case i want to know if i can remove them without affecting drivability....keep in mind there is no motor in my car right now so i can't just look to see where certain lines run.
^I think lines from this run to the smog pump?
^charcoal canister i think? but not sure exactly what it does...?
Last pic is for A/C...line on the right runs to the vacuum tree, and bottom two run through the firewall. Do they go to the knobs on the dash to control the A/C? I want to know where they run so i can disconnect them, becuase i won't be running A/C...
