I am a little lost when it comes to the whole chip/tuner thing.So my question is......With all the upgrades I have listed I still havent had a tune,is this something that I should do and how big of a difference would it be?Who is able to do this?
1994 svt cobra BBK underdrive pullies,cold air kit,long tube headers,Hurst shifter,4.10 gears,msd ignition,catless flowmaster exhaust,custom "Rodeheavers"subframe connectors,smog pump and a/c delete.
Definitely get a tune... I can't tell ya who to go to, but some people on here will be able to...
you'll gain some good power and responsiveness from it!
On a side note, were you at QSL in robinson tonight?
2015 Corvette Z06
- Shark Grey / Kalahari
How does the car run with the current mods you have on it? I had similar mods on my stock 95, minus the smog delete, and with 14* timing, I had no issues.
How much is it usually? No I was'nt in robinson tonight.I need to start heading up that way though.There is never any one out around here.
OK sorry... i saw a white cobra like urs up there tonight with some other mustangs.... I thought i recognized the one from the board, but I wasn't sure, so i decided not to say anything.
2015 Corvette Z06
I don't see where you would be gaining, not in power or drivability, that is if the car is running good.
Are you running a shorter belt for the smog delete? Instead of re-installing the smog pump, maybe look into running a smog delete pulley. I got one from ASP for my 347 for like $69 and it lets you run the stock belt.![]()
Did you bypass the A/C also? Just curious because I ditched my A/C also, but did not get a pulley. Was wondering if that is required?
I don't know much about the 5.0 crowd, but I've had two N/A 4.6 2Vs tuned and I don't think it's worth it. Unless you need a speedo adjustment, rear O2s turned off, it's not worth it for the maybe 5hp you gain.
Like stated above, if you don't have driveability issues, I wouldn't worry about it. Wait for a s/c or turbo to pay for a tune.
Maybe get a dyno with A/F and go from there, but you can still change the timing and fuel pressure manually on the 5.0 if need be. A tune for a N/A car with bolt-ons is not really a benefit in my opinion.![]()
2019 Colorado ZR2
With your current mods, there isn't anything you would really benefit from having a custom tune.
Hmmm ok, n/m then... the general consensus is not to get one. i just spoke from what i've dealt with, but i've also not dealt with fords... just assumed that they ford tunes were as conservative/bad as the gm tunes from the factory
2015 Corvette Z06
A tune is beneficial regardless of mods, even a bone stock mustang will benefit from one...especially the s197's. Only the buyer can decide if it is cost effective/necessary for their application...to do so or not. The choice is yours...good luck either way![]()
If his car was a modular, it may be worth it, but the pushrod mill in his car would see better gains by just dialing in the fuel pressure and timing via distributor adjustment. For what an actual tune and cost of a chip would run him, he could dam near buy a decent set of heads or at least a cam and intake upgrade.
Thanks guys.Once I get a supercharger its like a must right?
Once it's supercharged for sure. Oops, my bad! Didn't notice till just now this was in the "Ask the vendors a question" section. Feel free to delete all my posts. Don't want to be mistaken as someone contributing something useful.
X2! The only thing that sucks is that your car is a rare breed and there is little to no help in the way of flash based programmers. You can get a SCT or Diablo to tune idle and WOT but everything in-between is left to fend for its self. I have talked with the folks at both SCT and Diablo and they all say the same thing “our products don’t do much for the 94’s” but whoever said it would be wise to get it on dyno with A/F numbers is correct because you don’t want anything bad happening to that nice ride. PM me if you interested, good luck either way!
Predator Performance(814) 372-5431DuBois, PAHome of 2007 MM&FF #1 Mustang in the Country.
