Results 1 to 9 of 9
Thread: I think I like my heads again lol.
    Morgantown WV.
    563
    I think I know why I made less power than I thought with my head swap.
    My previous dyno sheet said I dynoed in 102* temps yet it was March 22 and I remember it being 60*. Well std numbers correct back to what I should be making at 60* So it adds hp to my final numbers. The program thinking it was actually 42 degrees hotter than it really was added a lot of hp. I probably would have only put out around 470-480 if the program would have used the correct data in figuring out the std numbers.
    I mean it did put out 516 at 12 psi on stock heads and intake which is unheard of.
    This time the temp on my dyno sheet said 86* which was accurate so it used the right data to figure the correction, So it actually made 520 this time. Which is 40 -50 hp more.
    Here's the run conditions of my previous dyno when I did 514/452. Correcting from 102* even though is was only 60* skewing the numbers
    Here's my last dyno sheet from last Tuesday. Here the temps recorded reflect the actual temps. So there wasn't as much correction as the previous time.
    So basically the time before the numbers were over inflated and this time the numbers were corrected correctly.I also broke 500 before 6k this time and it took to 6200 the previous time.
    Here's both complete dyno sheets
    Previous one
    Current
    I wish he would have turned a few more rpm and worked on the drivability a little more.
    I also whooped me a cl600 coupe tonight. He pulled beside and asked what I have in it. I just told him a Sc. then the light turned green.
    He started a couple cars ahead. When I started getting on it the race was on. I ended up about 8-9 cars ahead of him by the end of fourth. He was cool and gave me the thumbs up the.
    It just feels alot stronger up top to me. About like it used to in cold dry air even though it was hot and muggy tonight.
    665/540 New times coming
    5,822
    good. glad you're happy. looks like you pulled that second graph out of the garbage for the picture.
    Morgantown WV.
    563
    The first one was in a nice folder. The second one I just folded up and stuck in my pocket the day that I got it lol.
    On the first one the numbers were just over corrected. The ow rpm part throttle still has it's problems
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Another thing to remember that those ported heads won't show their true potential without a matched setup. What intake & exhaust are you running on the car?
    Mark Lowry
    Morgantown WV.
    563
    Stock intake, Mac headers, custom X pipe, and dumped dynamax bullets.
    Ligonier, PA
    6,365
    Quote Originally Posted by Jivepepper View Post
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Mars, PA
    1,696
    I'm thinking he means stock PI intake, not that rubber tube mess.
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    I would take it, look at the area under the curve. Also, was this being tuned or just dyno pulls? Your AFR look's leaner for the second set (more airflow). I would now be a little concerned with the AFR is headed with a boosted application. Probalby fine now with good gas, but you start moving more air and it could get ugle fast.
    Morgantown WV.
    563
    Quote Originally Posted by Slow01GT View Post
    Yep
    I think it's still around 85% duty cycle and I didn't have the KB bap turned up all the way so I hope I can make little more in the future.
    Plus I plan on retuning soon and working more on low rpm drivability.
  1. GT40 3 bar iron heads,NOT P HEADS!
    Last Post: 07-05-2014, 03:14 PM
  2. Lol
    By ModularMike in forum The Bar
    Last Post: 03-07-2011, 01:22 AM
  3. lol
    By blizzard in forum Pictures & Videos
    Last Post: 05-09-2008, 01:18 AM
  4. You will never believe this lol
    By mineralrob in forum The Bar
    Last Post: 12-12-2007, 11:47 PM
  5. lol *** N E M E S I S *** lol
    By Troll in forum Pictures & Videos
    Last Post: 06-02-2007, 12:39 AM
