Results 1 to 17 of 17
Thread: Hesitation Problem
    Selinsgrove, PA
    526
    Hesitation Problem
    Ok, well it seems to run fine when cold, then when it gets warm (around operating temp.) it will hesitate under heavy throttle for a few seconds, then will just haul ass (power comes back) then it will do it again under heavy throttle, it was popping/hesitating/bucking, and we timed it and put a stock thermostat back in it (was 160) and it seems fine now except for the hesitation, so far ive tried all of this:
    -egr valve
    -o2 sensors
    -iac
    -timing
    -tstat
    -compression test (was fine)
    -plug wires (msd s/c 8.5mm) (said to be good, but im not sure)
    -plugs(said to be good, but im not sure)
    -coil(said to be good, but im not sure)
    anyone know what could be causing this hesitation?
    help would be greatly appreciated!!!
    Fox/n.
    Ligonier, PA
    6,365
    a miss in one of your cylinders, do you have any way to scan it?
    check your wires, plugs, and all that stuff your not sure about.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Selinsgrove, PA
    526
    you really think its a miss?
    Fox/n.
    out in the woods
    4,948
    check to see if any of your wires are layin near the headers, or if one of them may have a rubbed threw spot to where when your under load it's sparkin out on the header.
    Gibsonia
    772
    If not ignition, i'd say fuel/ fuel psi maybe. How long since last tuneup?
    My collection:
    01 cobra in pieces
    02 dodge cummins
    Gibsonia
    772
    When its dark fire up the car, and look under hood to see if you have any arcing against header or what not.
    My collection:
    01 cobra in pieces
    02 dodge cummins
    Selinsgrove, PA
    526
    ive checked for arcing and did not see anything, and yes i have 1-2 wires that have rubbed on the header and have white burns on them and you can see the inside of the wire, so i bought msd s/c 8.5mm wires and put them on and it didnt help the pop/bucking problem so i took them back (lol), but the pop/bucking is gone and now it just hesitates.. so idk what is wrong..
    Fox/n.
    May 2008
    Pittsburgh
    229
    i got the same problem on my notch cant figure it out havent really looked into to much yet partin out my wrecked one rite now
    01' Gt=
    87' Notchback 5.0 =
    Ligonier, PA
    6,365
    Quote Originally Posted by Black87GT View Post
    yes because my car was doing the exact same thing and i had it scanned and thats what it was....misfire in cylinder 7 to be exact. lol. its because i had gotten water down in there....its all good now tho.
    1991 BMW 325iX
    1978 Ford F150
    Polar Vortex
    6,031
    Ignition module??? Have you checked it?
    Selinsgrove, PA
    526
    How do I check the ignition module?
    Fox/n.
    Polar Vortex
    6,031
    Change it One less thing it could be, plus it's probly original
    Selinsgrove, PA
    526
    well, now this morning my car is popping again like the timing changed, could this mean that my distributer gear/ distributor itself is probably bad?
    and another thing, should the rotor in my dizzy move at all when the car is off and trying to turn it by hand, because mine moves a little, and i dont know if that is normal or not??
    Fox/n.
    May 2008
    Pittsburgh
    229
    thats not normal at all ur rotor in ur distributor should not move at all
    01' Gt=
    87' Notchback 5.0 =
    Gibsonia
    772
    Mine always has a little play in it.
    My collection:
    01 cobra in pieces
    02 dodge cummins
    X2 - I believe these are known to act up when the get hot, but work fine when the car is cold
    May 2008
    Pittsburgh
    229
    that did happen to mine in my 92 went to hit it wot and it just died cooled down started up then would die put a new module on started up never had that prob again
    01' Gt=
    87' Notchback 5.0 =
  1. 2004 Mountaineer Throttle Hesitation??????
    Last Post: 12-19-2009, 10:12 PM
  2. 96 GT hesitation
    Last Post: 06-01-2009, 11:22 PM
  3. getting hesitation when shifting at higher rpms
    By DMmustangLX in forum Fox-SN95
    Last Post: 05-13-2009, 05:12 PM
  4. 5.0 Problem
    Last Post: 06-03-2008, 11:39 AM
  5. Hesitation only under hard boost
    By RUTHLESS in forum SN95-New Edge
    Last Post: 08-13-2007, 12:09 PM
