Results 1 to 7 of 7
Thread: Installing the Meziere electric water pump?
    Morgantown WV.
    563
    I'm installing the Meziere pump and with the idler I'm having a hard time getting the hex wrench on bolts especially the bottom one. It took me for ever to get the bottom one started.
    Is there an easier way?
    665/540 New times coming
    I just put one on two weeks ago. I got all finger tight and then had to make the short side an allen wrench shorter to clear pulley. I cut wrench with hack saw once I knew how short I needed.
    Be sure to wire this with a relay. I used two relays. One setup so pump comes on with key and other off a switch.
    Morgantown WV.
    563
    Also if you are running UDP pulleys. You will need a shorter belt. Atleast one size shorter than stock. I think I went two sizes smaller as I wasn't sure what would fit at time.
    I still don't see how you did the bottom one you can't see anything, and its between the crank pulley and wp idle pulley. I have the relay kit. Got it for all 287.50 shipped..
    I'm going to be running an overdrive crank pulley
    It can be done. Shorter wrench made world of difference.
    I edited previous as I forgot your supercharged and wouldn't be using UDP's
    Morgantown WV.
    563
    I'll go back out and try. I have already cut one wrench.
    Morgantown WV.
    563
    I got it! With a shortened allen wrench, and I used the piece I cut off. I tapered it on one end. I then took it and used a 6mm socket with a nut driver. That allowed me just enough angle to get at it.
    Thanks for the idea, and the help, much appreciated.
    Glad it worked. I can say this water pump has been some of best money spent on car to date. Atleast when it comes to keeping car consistent round to round.
  1. Meziere electric water pump
    Last Post: 05-28-2012, 09:13 AM
  2. 1994-95 Mustang Meziere Electric Water pump
    By Rio94gt in forum Ford Vehicles
    Last Post: 04-22-2012, 08:41 PM
  3. Electric water pump?
    Last Post: 06-21-2011, 07:00 PM
  4. Replies: 0
    Last Post: 08-31-2010, 02:21 PM
  5. 5.0 Water Pump
    By day9033 in forum Ford Vehicles
    Last Post: 05-07-2009, 05:40 PM
