Results 1 to 7 of 7
Thread: Compression test results. Please advise.
    Morgantown WV.
    563
    I took a compression test and had a couple questions about the results.
    I did this on a warm motor with the throttle body open cranking about 3 times per cylinder. Maybe I should have turned it over a few more times?
    This is the results
    Rear of motor
    124-125
    125-125
    125-124
    125-126
    My pistons are 18cc and with a stock head the c/r should be 9.0:1--8.9:1.
    But I have added Stage 2 heads with the swirl dams removed with the combustion chamber increased. I also have Hp cams with 531 lift. 114lsa and 240 duration. 292 duration advertised.
    I like how close the numbers are. But what about the cranking pressure?
    665/540 New times coming
    4,321
    crank a minimum of 5 times, but really until the guage stops rising...then thats your number
    Morgantown WV.
    563
    Well I cranked it 3 times and went out and looked. I borrowed the gauge so I hope it's ok.
    4,321
    Quote Originally Posted by Jivepepper View Post
    thats not going to cut it, either position the guage through your hood on your windshield so you can read it while cranking or get another person to help you...
    Morgantown WV.
    563
    Thanks.
    dude... the guage you used stores the compression until you release it.. and if you are not getting your number by 3 spins then forget it!!!! if you remember you did that one cyl like 5 or 6 times and it was no different than the others.. you want to try and turn it over the least amount of times possible if you are trying to find a problem, so 3 times is perfect, it will present a problem plain as day..
    4,321
    yes the guage stores compression but if you haven't built up enough compression it's only going to show what you have to that point. you must keep cranking until the guage stops for an accurate reading...
  1. Replies: 31
    Last Post: 12-14-2011, 09:04 AM
  2. advise needed here
    Last Post: 02-10-2009, 02:44 PM
  3. Dyno Test Results!!!!
    By mike5oh_93 in forum Pictures & Videos
    Last Post: 05-03-2008, 04:49 PM
  4. '03 Cobra question & advise
    By pasvtx2 in forum SN95-New Edge
    Last Post: 08-08-2007, 03:07 PM
  5. Compression Test
    By RUSH2112 in forum Fox-SN95
    Last Post: 11-30-2006, 06:43 PM
