Thread: sub frames!
    Senior Member yellowstang03's Avatar
    Dec 2007
    Ligonier PA
    796
    sub frames!
    so me and joe went to laurel mountain mustang and picked up a set of there sub frames and the torque box plates also. i was wondering if anyone has any pointers before i started or anything to make life a little easier?
    03 gt kb
    Put the frames on with the suspension loaded!!! As you were sitting in your driveway. In other words, when you jack the car up, put blocks under the wheels and not the control arms. Make sure the front wheels are at the proper ride height before you weld. I usually do it be placing a 2X4 on the outter edge of the tire between the tire and the block. That puts the wheels at the correct ride height.
    Dec 2007
    Ligonier PA
    796
    im not worried about the sub frames really...the torque box kit looks like its gonna be a treat though haha
    03 gt kb
    Quote Originally Posted by yellowstang03 View Post
    Uppers, lowers, or both?
    The lower kits are so darned easy, just remove the control arm nut, fish it in there, start the nut drill 4 holes, bolt them down and then tighten the control arm nut back up. Real easy.
    The upper you do have to remove the control arms, and make sure you have good drill bits so the don't want to walk, especially on the ones up top, plus that area is thicker.
    As was said, make sure the car is set up with the tires loaded to do the subframes, and the plate with the SFC's from LMM make it easier becuase it give you more to weld too.
    I have the LMM SFC' and upper and lowers on my car if you want to see how they are installed. All nice pieces.
    Bob Myers
    Dec 2007
    Ligonier PA
    796
    you guys are gonna laugh how i have my car up in the air...we only have a 2 post lift so i used 4 55 gallon drums and set it down on them hahahaha i'll get some pics.
    03 gt kb
    Dec 2007
    Ligonier PA
    796
    bob, im doing uppers and lowers. after looking at it with the car in the air its not bad at all. i hope they help it out some...
    03 gt kb
  1. full length sub frames and gauge pod sn95
    By yeahloh95 in forum Ford Vehicles
    Last Post: 11-01-2011, 06:57 PM
  2. Where to get sub frames welded on
    By Maxpowers in forum General Tech
    Last Post: 10-25-2011, 09:08 PM
  3. 10 bucks says the frames bent
    By 92306gt in forum Pictures & Videos
    Last Post: 02-02-2008, 03:44 AM
