Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Back from the dyno again lol.
  1. #21
    i think he may have tryed to richen it up at the injector to overcome a pump delivery problem..
  2. #22
    fairmont,WV
    1,352
    hey jive what are you using for tuning? a chip or handheld? If your using a SCT Xcal then you can datalog your car yourself and see your injectors and pump while just driving and on WOT. Those numbers would tell you wether or not your running out of fuel.
    XXX RWHP
    XXX RWTQ
  3. #23
    Morgantown WV.
    563
    I'm sorry, I don't in any way want to call a professional wrong or call him out, but there's a lot of power left in the A/F ratios...
    This may have been asked, but are you tuning it via MAF or SD? At that power level, i'd think you have to be reaching the edge of what the MAF can handle? I had no choice but to go with SD - the only problem is, though SD is great, it takes even longer to get dialed in - therefore its more expensive - mine still isn't perfect... and i think its a little more finicky with changes in temperature/humidity/etc, but not positive with that
    SD? I'm using a sct 2400 maf and they installed a Diablo mafia
    Chip, the very first one the SCT came out with. I was talking to rich, and he said he would data log for me. But I'm pertty sure I going blow through instead drawl through.
    665/540 New times coming
  4. #24
    Spencerport, NY
    3,762
    SD = Speed Density
    I use a 3bar speed density tune on my car.... once you go beyond the amount of air that a MAF can read, you need to go SD.... The LSx PCM can run on SD(2 or 3bar) as well as the factory metered air setup (MAF). I'm not sure if the mustang PCM's can do the same without getting a standalone system, but i'd suspect they would...
    2015 Corvette Z06
    - Shark Grey / Kalahari
  5. #25
    fairmont,WV
    1,352
    well jive im down to help data log and stuff w/ rich or whatever you need. and if your using a 2400 MAF w/ a MAFia I seriously doubt you are maxing it out. Im still using the stock MAF w/ a MAFia and Im no where near maxing it out. Im sure once you get it logged on the street, you will find what the problem.
    Mike
    XXX RWHP
    XXX RWTQ
  6. #26
    Morgantown WV.
    563
    Mike
    No I'm not pegging it but I was before tha mafia. If I go to blow through it can lower the working range of the maf and I'm hoping I'll still have enough after the change over. Twin srews require less maf for the same amount of power than a turbo or centrifuge sc..
  7. #27
    I would love to sit down and have someone explain this theory of tuning to me.
  8. #28
    Spencerport, NY
    3,762
    Mike
    you're also not running anywhere NEAR as much power as him .....
    Jive, If you can run MAF, that's great - i'm not saying its a bad idea - i'm just saying i'm surprised... atleast for my car, i thought i remembered MAF's being maxed out around 8-10psi... which should be in the area of 550-600rwhp .... the mafia extends that range, but i'd be surprised if it makes you able to go very far beyond your current hp range... ?
    i'm sorry, that's off topic - just a thought if you can't get your driveability - however, i wish you good luck... i'm sure you'll get it figured out - just takes a little patience!
    2015 Corvette Z06
  9. #29
    Morgantown WV.
    563
    If you look for joe's TT GT on youtube you can find where they used a maf on it until 1100rwhp. Now it was either the 2800 or the 3000. My 2400 on cobra is could to 600rwhp. Then there's the 2600, 2800 and the 3000.
    It does take patience and all your money lol.
  10. #30
    Spencerport, NY
    3,762
    Quote Originally Posted by Jivepepper View Post
    cool - well as long as its working for you, then go for it...
    2015 Corvette Z06
  11. #31
    it not a good way to do things but i have heard on guys trying to lengthen the IPW to overcome weak fuel delivery.. it is more like a bandaid for other problems..just a thought or what he may have tryed to do..
  1. TTSaleen back on the dyno!!
    By 98saleen in forum Pictures & Videos
    Last Post: 11-24-2011, 04:46 PM
  2. Back from the dyno.
    Last Post: 04-07-2009, 09:10 PM
  3. Replies: 29
    Last Post: 06-18-2008, 10:27 PM
