Results 1 to 5 of 5
Thread: install
    NEWB
    167
    install
    I'm coming home from maryland this weekend and we begin to start project i have on my hands. Im going to be install a trac-loc dif with the carbon clutches, 31spline axles, an aluminum driveshaft, and a GT supercar fuel pump.
    i have all of the parts and tools for the fuel pump install.
    my question is did i forget anything for the dif install
    gear oil, rear end girdle, wheel studs, friction modifier, new driveshaft, driveshaft loop, axles, dif.
    should i get new exciter rings(i think thats what there called) from the getgo or can these be salvaged?
    any suggestions on other things to do or something i forgot please remind me now before i have the call all apart and i realize im an idiot.
    2001 Black Gt 5spd
    Kenne Bell is my BOY
    NEWB
    167
    can someone at least say that you think im ok to make me feel better. hahaha
    2001 Black Gt 5spd
    Spoon Killer HidalgoGT's Avatar
    Uniontown
    1,792
    You can salvage them if your careful. Sounds like you have what ya need for the rear. Good Luck.
    2001 Dodge 2500 The Big Bad "D"
    4" exhaust,38"MTZ's,5.5 Fabtech Lift,Cold air intake,Silencer ring MIA,Smarty tuner,Edge Drag comp, 64/71/.80 s300 turbo 175hp injectors.
    321Hp/783Tq New power numbers this spring.
    1987 Dodge 1/2 ton gasser 4x4 "jr"
    Ricers: For those who don't have the balls or skills to drive American Muscle.
    Not cool cause I don't drive a mustang anymore.
    Got Smoke?
    http://www.youtube.com/watch?v=BGIvJflAxZU
    Did the new diff come with a cross pin and cross pin retaining bolt? retaining bolts are sometimes broken, cross pins get a bit beat up depending on milage / abuse.
    I didnt see and mention of carrier bearings and set-up shims? Or are you going to press your old bearings off to install the new diff? Either way you likely need shims and marking coumpound to set back lash. There are basic install kits that have the shims, compountd and a few otrher bits just ofr this purpose.
    What about ring gear bolts? gonna re-use?
    I ddint see loctite on the list, will need that for ring gear bolts, and drive shaft bolts at least.
    The exciter rings can be pressed off and pressed back on.
    I see wheel studs. Are they stock length or long ones? If long, do you have open end nuts?
    Random thoughts.
    Bob Myers <- Plans everything to death
    NEWB
    167
    i have loctite. i got moroso 3in wheel studs so i think im gonna need open ended lug nuts. the guy that i talked to wasnt sure weather the nuts i have would cover the distance or not.
    does anyone know how long the stock wheel studs are on mustangs?
    I was thinking about gettin one of those install kits, but wasnt sure if i'd need it. Do you think I need new carrier bearings and such with 50,xxx miles on my car?
    If the cross pin and bolt are bad ill just run and get them from woltz and wind(local dealership). same goes with excited rings.
    2001 Black Gt 5spd
  1. Gear install
    By mustang50lx in forum General Tech
    Last Post: 06-05-2008, 10:11 PM
  2. Nitrous install
    By fork5o in forum General Tech
    Last Post: 05-24-2008, 01:26 PM
  3. Install subframes
    By scott5 in forum General Tech
    Last Post: 04-10-2007, 03:45 PM
