Results 1 to 7 of 7
Thread: which way do i install rear main seal? pics inside...
    State College, PA
    3,552
    ok not 100% sure on which way to install rear main seal. it's the 1 piece fel-pro if that makes a difference.
    pic 1: this side is flat
    pic 2: this side is cut out.
    I think the flat side goes toward the flywheel, and the cutout side goes toward the inside, is that right?
    also, when installing this while putting my shortblock together, should i put this around the end of the crank before putting the rear main cap on, OR install the rear main cap Then install the seal?
    2013 Mustang GT
    1999 Contour SVT
    out in the woods
    4,948
    spring side goes in towards the block.. you can install after you put the cap on. just leave the rear two 1/2 inch oilpan bolts loose until it's in.
    State College, PA
    3,552
    didnt even notice that little spring in there till you said that lol thanks for the reply!
    2013 Mustang GT
    1999 Contour SVT
    out in the woods
    4,948
    I geuss I never messed with the V8 stuff, but our 4 cylinder seals come with a little clear plastic sleeve to keep the lip from folding over furing install. Did you remove that, or don;t the V8 ones come that way?
    As was said, the spring goes to the wet side ;)
    State College, PA
    3,552
    nope, dont think the v8 ones come with that...just pulled mine right out of the box and took pics. i didnt mess with anything
    2013 Mustang GT
    1999 Contour SVT
    make sure you lube up the crank a little before putting it on, this will help it to not tear of scratch up the seal..
  1. Rear main seal replacement 03 Cobra
    By Terminated in forum SN95-New Edge
    Last Post: 02-01-2012, 01:49 PM
  2. SN-95 5.0 rear main seal replacement
    Last Post: 02-18-2011, 01:50 PM
  3. rear main seal questions???
    By White5.0 in forum Fox-SN95
    Last Post: 06-18-2010, 01:14 PM
  4. Rear Main Seal 04 Cobra
    By burntire in forum SN95-New Edge
    Last Post: 01-26-2009, 07:46 PM
  5. It is never simple, which rear main seal?
    By DRRummel in forum Fox-SN95
    Last Post: 11-21-2008, 10:36 AM
