Hey guys heard about this site from a few different people and since i just drove out to ohio and bought a 2003 torch red cobra with red and black leather figured it was time to join. The car had 19,000 miles on it when i picked it up. there are alot of mods but here are some. kenne bell 2.2 running around 20#s. 60# injectors, kenne bell bap. LFP heat exchanger, LFP larger holding tank, canton expanded resivor/SLP line lock, mgw short throm shifter, centerforce dfx clutch and flywheel. liberty 26 spline input shaft, DSS level 5 halfshafts, catted x pipe with magnaflow catback, biletflow irs brace, oil water seperator, intercooler pump mod,fiore clutch quadrant and firewall adjuster, H&R lowering springs, 18X9 fronts and 18X10 rears with 285/35/18 nitto555r. k&n fipk, raptor shift light. autometer boost gauge and oil pressure gauge. dynojet wideband with air/fuel gauge, maf etender,mm diff bushings,subframe connctors,mm irs bushings,billetflow irs mount brackets, php toe link bars. thaink thats it. by the way my name is jason. this is the only pic i have at the moment.
