Results 1 to 6 of 6
Thread: how to identify 2.3 vs 2.5 ranger motor?
    Member 1badnotch's Avatar
    Northern Cambria,PA
    1,366
    I just bought what I thought was a 2.3 ranger motor from a '95 ranger. I was taking it apart and noticed that it doesn't have provisions for a distributor. No hole in the block,no dummy plug,nothing. It also has the low mount,passenger side alternator. Is this possibly a 2.5 motor? I'm not 100% sure that this was the original motor from that 95 ranger either. What year did they start making the 2.5? Any other ways to identify a 2.5? Thanks.
    Mark
    They get tricky....
    Does it have a harmonic balancer or just the pulley? 2.5's got a damper.
    Measure the crank throw ;)
    It does sound like a 2.5 to me right now. If you cant use it, lets talk ;)
    Northern Cambria,PA
    1,366
    2.5
    Bob,
    I just checked and it does have a harmonic balancer,so I guess that I have a 2.5. I bought it mainly for the cylinder head(which,I noticed has the small diameter valvesprings)because the one on my N/A 2.3 was cracked between the valves on #3 cylinder. Now that I know it's a 2.5,I am going to check into building my turbo motor a 2.5. I've heard that you use the 2.5 crank and main caps and buy spacers since it's a small journal crank. I've also heard that you have to buy rods and pistons,because the stock ones are powdered metal and cast. I think that I'm going to at least check into it. If I decide to get rid of it I'll let you know. Thanks for the info!
    Mark
    You have the general idea. There are a few other ways to use the crank as well. Even if you dont use the 2.5 block, save the caps. You can use 1/2 a set of spacers, the small caps, then not ot have ot worry about the spacer spinning (becasue the small caps lock the top half in with a large journal block. To use a 2.5 crank you will need higher cost rods and custom pistons, so the price adds up pretty quick for .03 liters. Blow on it harder :D
    The dual plug heads and those valves get complicated pretty fast. None of the "turbo" geared stuff works with that valvetrain. It can be done, but cams get funny. I have a couple of core heads around, but they need checked for cracks too. Basically, if it's a 2.3 head, it likely has cracks somewhere. the question is can you get around them with big valves / seats.
    Let me know, I have something I want to play with a bit.
    I had a 95 ranger with a 2.3, and I know it didn't have a distributor (whether it had the provisions for one or not I don't know). And it also had the low mount alternator I believe(but I forget which side, I just remember replacing it and I think I recall it being on the bottom).
    2007 Chevy Silverado, 4x4, 4.8L V8, Reg Cab,
    1990 Bronco 2, 4wd, 5 spd, 2.9, 205,000 Miles, 3" body lift, 31x10.5's
    85 Shadow 500
    Northern Cambria,PA
    1,366
    2.5
    Bob,
    I sent you a PM about the shortblock. Let me know. Thanks.
    Mark
  1. Coilovers, can you identify these
    By madmaxin22 in forum General Tech
    Last Post: 06-12-2014, 07:42 AM
  2. Identify this clutch
    Last Post: 05-18-2011, 10:17 AM
  3. 3.0 ranger motor
    By blksunshine88 in forum Ford Parts
    Last Post: 03-06-2010, 10:01 AM
  4. can someone identify this part
    Last Post: 03-01-2010, 07:17 PM
  5. help me identify this FPR
    By White5.0 in forum Fox-SN95
    Last Post: 07-27-2008, 02:10 PM
