347 stock block,FPS forged crank and rods, JE pistons 10.5:1, main girdle,comp .555/.565 hyd. roller cam,vic. jr. intake, holley 800cfm carb. AFR 185 heads, hooker supercomp 1 5/8" headers, romac balancer, MSD dist. and wires, motorsport valve covers.
Suspension:
D&D tubeular K member,A-arms coilovers.lakewood 70/30 struts,5 lugs conversion.REAR: baseline susp. upper control arms and brace, hotckis lower, lakewood 50/50 shocks, moser 33 spline spool,5 lug axles and c-clip elem, 4.30 motive gear. S&W racecars 8 pt cage, subframe conn. Misc:
Alum. radiator,optmia batt.,MSD 6al and timing control,auto meter carbon fiber tach, auto meter oil pressure,water temp gauges tci flywheel built pa c4 tranny with reverse valve body 4200 redneck converter weld wheels 26 11.50 et streets car has open long tubes on it currently
can send pics upon request to large to load on here
