Here are some pics from the race:
My youngest brother's girl got some vids if they ever get around to sending them
Both Cars look great!
Have you run the blue LX in the 1/4 yet? If so, what does it run?
Nice shots J.
Where's the mountain of beer cans?
Mark Lowry
Unfortunately... 11.39 @ 132 w/ 60s in the mid 1.8s
The car has a ton more in it, but the Tremec TKO600 will not shift into third at the track. It is at Pro Motion Powertrain in FLA hopefully getting fixed under warranty.
Made 598/580 on 7.1 psi and a conservative tune.
Once the trans issue is fixed i'll be getting a cheap boost controller and going back for a tune hopefully at 15psi on E85
It was just nice to get the car to the track.
Cool pics! They certainly are beautiful Stangs
United We 'Stang2002 Mineral Grey V6 5-spdCount Your Blessings, not your Problems
Thanks.
15x10s and 325/50 Mickey's like a 28x13 slick I've been told, wanted the 15x12s but my builder said stretching the DRs wouldn't work well like a bias-ply.
I obviously need more testing, but the car has been difficult to balance bog vs. spin the 10 passes I've made.
Best 60 was 1.78 and that was when I wasn't trying to launch, just make a clean pass and hit the gear, and I left like i would on the street and it hopped slightly probably 10-12 times but went forward.
Plan is to get the trans back and I'll take the last week of Aug. off. If the trans will shift at the T&T that week I'll take it to NMRA Columbus---my chassis guy will be at both so hopefully we can get it ironed out.
Later, J
yeah, search posts I've started and you will find a lot of build pics the chassis shop and I took....TeamZMotorsports did all the chassis/suspension/turbo
Sweet! I'm highly considering a set of MT drag radials 325-50-15 but i'm not sure if they will fit. I have a set of 28 x 12.5 MT et streets now and they are a pretty tight fit.
What t&t are you going to? PRP?
Dave seems to be a great guy to work with and his works looks unbelievable!
Do you post over at sbftech? Whats your screen name?
