Results 1 to 10 of 10
Thread: are 36lb injectors too much for my motor?
    Bridgeville
    1,278
    Ok so my buddy has a set of 36lb injectors 4 sale....im looking to upgrade mine..im sure everyone knws my motor..full bolt ons, forged pistons rods, ported heads..30 over, stg 2 cams, an a lil over 10 5 1 compression. i still got the stock injectors. but wana upgrade....r 36lb injectors too much 4 my application? i plan on runnin n20 in the near future...100 shot
    Polar Vortex
    6,031
    I think you should wait till you get a nitrous kit hooked up, then put the 36's in and get it tuned with a flip chip, otherwise you may have some drivability issues if you put them in now
    Bridgeville
    1,278
    ok so if i wanted to upgrade my injectors for n/a without spray what lb should i go with?
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    id go with 30's, leaves some room for xpansion and no driveability issues
    All stock down to the tires
    355hp n/a
    520hp on nitrous
    Bridgeville
    1,278
    i was thinking 30s an 90mm lightning maf.....does that seem like a good combo?
    Bridgeville
    1,278
    will i need an adjusted tune with my sct2 programmer once the new maf an injectors go on?
    NEWB
    167
    yeah you'll have to have a tuner calibrate the MAF to the injectors and they'll probably have to adjust some other stuff when your in there.
    2001 Black Gt 5spd
    Kenne Bell is my BOY
    Quote Originally Posted by PunisherStang View Post
    I don't know (and neither will anyone else).......Are you currently running out of injector now?
    Bridgeville
    1,278
    No but id like to upgrade them bc im going to be getting spray an a dyno tune shortly
    Mars, PA
    1,696
    Even with spray I think the 36's are too much for an NA motor. IF you are running a wet kit then 24lb injectors and a different fuel pump like the svt focus should be more than enough for you.
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
  1. mach 1 motor vs cobra motor
    By 89stang in forum The Bar
    Last Post: 07-28-2011, 10:45 PM
  2. injectors
    By cemnt guy in forum Ford Vehicles
    Last Post: 01-13-2011, 03:00 PM
  3. Replies: 0
    Last Post: 01-07-2009, 12:08 PM
  4. Lightning motor vs regular f150 motor
    By scott5 in forum S197
    Last Post: 08-18-2008, 04:15 PM
  5. pro-m mass air and 36lb inj
    By ocracing in forum Ford Vehicles
    Last Post: 12-03-2007, 11:10 PM
