Results 1 to 7 of 7
Thread: No spark
    North Hills
    1,229
    No spark
    This is a longshot. but I am getting no spark.
    I was having some surging issues at red lights/stop signs. so i replaced my TPS. i had to give a small, but not too hard tug on my harness to get some slack for the connector. after that, i have gotten no spark.
    not with the new tps, not with the old one. not with a new module, coil, or bypassing the msd Box. im pretty sure i am getting spark into the coil, but none out to the distributor. it wont even arc to a screwdriver, so it is Pre-plug wires i believe.
    wondering if there is anything else you guys can think of before i pull my upper to look at the harness more in depth?
    Thanks.
    for anyone who doesnt know, car is an 87 GT with a MAF upgrade.
    Im at the point of just thinking of buying a new harness.
    North Hills
    1,229
    hellllllllllllllllllllp
    May 2008
    Pittsburgh
    229
    u have power at the coil but no spark get a volt meter and put the negative on a good ground and put the positive on the casing of the coil if u r pickin up voltage on the casing the coil could be defective
    01' Gt=
    87' Notchback 5.0 =
    May 2008
    Pittsburgh
    229
    u say u converted ur 87 over to maf i am interested in nowing what u did to do this cause i have an 87 notch that i am going to convert
    01' Gt=
    87' Notchback 5.0 =
    North Hills
    1,229
    not recently... but it was a harness, meter, computer. i believe that was all
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    its the block. give me the 331. I'll take it off your hands.
    2015 GTPP
    North Hills
    1,229
    HA. what 331? its a reg 5.0. i didnt drop the cash on a big boy block yet
  1. 5.0 loosing spark
    By 1natehanson in forum Fox-SN95
    Last Post: 09-12-2010, 04:31 PM
  2. 95 5.0 no spark no fuel
    By 95gts in forum Fox-SN95
    Last Post: 04-11-2010, 06:07 PM
  3. 95 GT with No Spark
    By real_jeff in forum Fox-SN95
    Last Post: 12-27-2009, 12:17 PM
  4. Spark Plugs
    Last Post: 07-28-2008, 05:53 PM
  5. No Spark!!!!
    Last Post: 11-19-2007, 08:07 PM
