I have posted before about my car. I have an 87 5.0 with a trick flow kit from summit. heads intake cam etc. 24 lb injectors 255lph fuel pump, 91 or so computer and wiring harness. (it has the air bag connectors on it) We have tried everything including changing computer. however I did not change the engine harness so the 91 harness from the computer plugs into the 87 underhood engine harness. I am thinking that its possible that the temp control sensor is is not hooked up or the wires suppose to be going to it are not there. The car runs alot better cold, then turning around and coming back runs very bad. I think that the computer could not be reading that sensor therefor throwing fuel to the car? Does anyone know if that is or could be the problem.? Anyone have any other suggestions to what it could be? Anyone ever done a maf conversion without changing engine harness?
THanks for your help
