Results 1 to 5 of 5
Thread: Torque specs on rockers
    LowHill
    2,679
    Anyone know the torque specs on motorsport 1.6 roller rockers? I got a set used and wanted to put these on.
    Castle Shannon
    1,276
    no torque. tighten to zero lash then 1/4 turn and lock em up. and you have to do each pair at tdc on compression
    State College, PA
    3,552
    No, this is wrong.
    For pedestal rockers, You tighten to zero lash, THEN torque the spec. which is 18-20 ftlbs. you then determine how much of a turn it took to reach the torque spec....it should take between a quarter to one full turn to reach spec. if it reached the torque in that range of a turn, then you are good.
    if it took more than one turn, you must shim the pedestals. if it took less than 1/4 turn, you need longer pushrods.
    2013 Mustang GT
    1999 Contour SVT
    Ryan is correct on all aspects. You should check the swept area on the valve though too. It can be changed with shims and pushrod lengths, but its much harder to get perfect than a stud mount setup, but once you get it setting them up again in the future is a snap!
    I have always did mine to 18ft. lbs. and about a half turn. You should hit your torque setting at that half turn if that makes any sense. Anywhere from 1/4 turn to 3/4 turn is alright.
  1. Ford 9inch torque specs & bearing preloads
    Last Post: 01-02-2012, 11:56 AM
  2. Fox body lugnut specs
    By White5.0 in forum Fox-SN95
    Last Post: 02-03-2010, 01:18 AM
  3. Trickflow Kit specs
    By scott5 in forum Fox-SN95
    Last Post: 09-10-2008, 04:15 PM
  4. Need Help on specs 1994 v6 engine and t5 trans FAST
    Last Post: 04-08-2008, 08:45 PM
  5. Replies: 3
    Last Post: 04-21-2007, 08:38 AM
