im selling all of the stuff that im going to replace for the new combo..prices are fairly firm but it never hurts to ask.....
410 stroker (2000 miles) 14 passes ------ 3000.00
74w block .040
eagle 4340 forged crank
eagle 4340 h beam rods
srp dished pistons ( 10.5.1 w/58c--11.1 w/ 54cc)
melling oil pump
comp hardened oil shaft
zero balnced
sfi balancer
sfi flexplate ( 157th c4 )
1/2 head studs
camshaft innovations .700 lift solid roller billet cam
comp billet timing chain
canton main girdle
canton windage tray
canton pick up
canton dip stick
canton 7qt oil pan
car ran 10.51@131 n/a and 9.50@145 on 150 shot there was way more in it, just wanting to step the game up a whole bunch...
tea 225 cnc high port heads 54cc ( 345/260 ish @.700 ) ----2100.00
with comp hi tech push rods ( 1 peice ) set up for solid roller
must use a 1262R intake gasket
pro systems 1000cfm hp race carb ---- 700.00
comp ultra gold race rockers 7/16 stud -----175.00
trickflow highport stud girdles ---100.00
hooker super comp 2inch headers ------350.00
3.5 inch collector 351 swap
edelbrock super vic 351 intake ----175.00
zex perimeter nitrous kit 100-300 hp -----450.00
w/ zex big noid purge, bottle heater, autometer 2 5/8 incar gauge ,blow down tube
wot switch for holley carb
aeromotive 13204 fuel press reg ---- 100.00
comes with regulator fittings
aeromotive a1000 w/ fuel filter ( 100 micron ) -----250.00
msd pro billet distributor ---- 200.00
mech advance 351 ( used with my super vic intake )
dedicated nitrous fuel system ---- 300.00
holley blue pump
holley 12-803 reg
fram fuel filter
6an earls pushlock
all an fittings bolt on and go
15x10 weld draglites ---- 350.00
4 lug
drilled for screws ( screws included)
with 28x12.50x15 et streets 65% tread
weld draglites 15x 3 1/2 ----250.00
with 90% front runners
4 lug
31 spline moser axles w/ long studs ----- 250.00
c clip eliminators
4 lug
31 spline trac loc 8.8 center recently refreshed ---- 100.00
msd digital 6 ignition ---- 150.00
msd blaster ss coil ----25.00
dynomax ultra flo welded mufflers 3inch ----75.00 pair
cervinis 4 inch cowl hood 87-93 ----- 350.00
painted flat black primer
autometer 2 5/8 fuel press gauge 0-15 psi ---- 30.00
i have 2 of these
art carr 1000 hp c4 FRESH ZERO MILES ----- 1000.00
hardened input shaft
pro billet trans brake
rev manual v.b
sfi jw bell
trans mount
alto red eagle clutches and steels
locking dipstick
deep aluminum pan
6 gear low drag planetary gear
fully rollerized
billet servo
plus much more...
ultimate converter concepts 9.5 c4 4200 converter ---- 400.00
fresh 2 months ago , 6 pass's
was redone then at ucc by lenny
3.73 motive gears --- 75.00
b&m ratchet shifter ----125.00
cable
brackets
polsihed cover plate
transbrake button shift knob
stock 87-93 hood red ----50.00
great condition
looking to buy another mustang for a driver/strip car to play with, so keep that in mind.... with a deposit i will meet within a reasonable distance on most of the bigger stuff, as i dont want to ship that stuff, please email ruthlessgsx@aol.com or call 814-207-3299
thanks
