Results 1 to 8 of 8
Thread: double roller timing chain vs. gear drive?
    which is better in a 408?what actually does the gears do over a chain?any input is helpful thanks.
    I would not use a gear drive because of the harmonik vibrations they make, you cant hear them or feel them but they reak havok on other parts... i would stick with the good ol double roller..
    thanks tim
    I think gear drives claim that they're more accurate, since chains may stretch some over their lives. I don't know about Ford engines, but I know certain year sbc's required machining for the gear drives to sit right against the face of the block.
    Just my 2 cents... but always degree your cam when installing a new chain, to make sure everything is right. I put a new chain on the 455 Olds I was building this spring, thought I put it on straight up, reusing the same cam, thought I didn't need to degree it. I hung all 8 exhaust valves open, nicked the tops of the pistons, got crap down in the rod bearings. $600 lesson.
    ChuckT
    Sponsored by
    Millerstown Pic A Part
    408 Fox Chance Sumney's Avatar
    Jul 2008
    Washington, Pa
    3
    Hey im putting a 408 together right now and i put a double roller in mine.
    In the process of putting together a 408w backed by a tko 600 and a 456 gear.
    thanks guys good info coming from you guys.didn't really make up my mind yet though
    If your looking for something really accurate, go with the Jesel belt drive.
    Buy a good double roller chain with a thrust bearing set up and call it a day. I do not like gear drives because of all the vibrations they induce into the valvetrain.
  1. WANTED 86-93 302 Timing chain cover
    By Donstang86 in forum Ford Parts
    Last Post: 04-01-2014, 05:35 PM
  2. 30k cadillac timing chain shot
    By 92306gt in forum The Bar
    Last Post: 11-04-2011, 05:55 PM
  3. Timing Chain And Gears Help
    By 955.0 in forum Fox-SN95
    Last Post: 02-02-2010, 10:54 PM
  4. WTB timing chain cover 5.0
    By jaa55 in forum Ford Parts
    Last Post: 04-23-2008, 11:44 PM
  5. 5.0 timing chain
    By eddmann55 in forum Fox-SN95
    Last Post: 12-28-2007, 09:05 AM
