Results 1 to 6 of 6
Thread: running lean???
    Mt Pleasant
    2,916
    running lean???
    i took the heads off a nearly stock 91 mustang with 95,000 miles and all the exhaust valves are white as a ghost. the car seemed to run ok until you got past 4000 rpm and than it seemed to quit making power. some of the plugs were pretty white also. i know its a lean condition but wonder what caused it. i just started a h/c/i swap with this car and im just trying to figure out why it was running so lean
    LowHill
    2,679
    should have put a FP gauge on it and see if it lost FP with rpm's, could have been pump or regulator.
    Fuel pressure? My valves were red as a crayon. HAHAHAH
    3,356
    Yep check for the proper fuel pressure under load. It would also be a great idea to check the WOT A/F ratio as well and report back or take it to a good dyno shop once you install the h/c/i etc!
    Mark
    LeMans Blue Z06
    LowHill
    2,679
    A buddies car wouldn't pull past 4grand and the fuel pump was going out. He changed pump and the car runs fine now.
    Mt Pleasant
    2,916
    they look a little red in the centers
  1. Running Lean...MAF need upgraded?
    By Zoom50 in forum Fox-SN95
    Last Post: 06-20-2014, 09:17 PM
  2. Sitting with a lean
    Last Post: 08-18-2011, 05:11 PM
  3. Running way lean
    Last Post: 08-08-2011, 11:43 AM
  4. running lean
    By 95V6 in forum SN95-New Edge
    Last Post: 12-12-2010, 12:18 PM
  5. Replies: 1
    Last Post: 11-18-2010, 12:11 AM
