Results 1 to 14 of 14
Thread: HELP no full throttle- falls flat?
    GREEN=FAST sweeney1030's Avatar
    johnstown
    570
    my wifes 02 has an issue I cant figure out. It runs great until aprox 3500 rpm then it falls on its face . I changed the fuel filter twice checked the injectors and cleaned all the fuel lines with air and cleaner. the pump is working I wonder can a efi vapor lock it feels like its starving for fuel.ANY ideas?
    1990 lx silverworm's Avatar
    monroeville pa
    309
    my 97 did that to me two diffrent times, 1st time was a clogged cat, 2nd time was an o2 sensor went bad.
    johnstown
    570
    no cats and o2s are ok checked voltage , this sucks where is the fuel pressure regulator on a 02 6er
    Mt Pleasant
    2,916
    try unplugging the mass air sensor and see what it does
    1,220
    Cleaning the Mass air flow sensor may fix it too.
    Jan 2008
    Jefferson
    4,674
    Check the fuel pressure off of the rail. It looks like a tire valve stem. It should be close to 40 psi. If it under 30 and the filters new. It could be a pump. Idk its hard to diagnose somthing without actually seeing the car.
    johnstown
    570
    thanks guys Ill try those all tomorrow and post the results, Im ready to burn the fukker
    Oct 2007
    3,125
    also try unplugging the fuel rail pressure sensor. I doubt it would blow on a 6 cyl, but hey it could happen I blew my FRPS about a month ago and the car was completely undriveable and I had it flat bedded home. Some guys experience symptoms similar to what you're experiencing though, but thats mostly 03/04 cobra guys where the part has a tendency to fail.
    johnstown
    570
    it feels like a clogged cat but like I say they are gone , Im gonna drop the tank check the pump and clean the inlet screen after I check the pressuse at the rail. the car is run pretty hard I just hope something is'nt hurt if it is Im goin with a carbed pushrod plant and a c4 I have left over.
    I was thinking the same thing as Bo. Sounds exactly like what happened when my car blew the fuel rail pressure sensor. Would drive fairly normal under light throttle, but anything over about 1/3 throttle would bog horribly.
    johnstown
    570
    thats what its doing good description I m going to work on it now Ill keep ya posted
    johnstown
    570
    the stupid tea bag looking filter on the out side of the pick up was clooged as was the netted one on the inside on the pump - cost 6 bucks to fix it what a phunking pain in the butt
    Fort Eustis, VA
    525
    Thats what was wrong with my old toyota pick up DD when I first got it. It was a pain in the A@# but glad it was a cheap fix. Although a lil easier on my truck due to no need in jacking the truck up. Glad its fixed though
    86 Notch New Project
    johnstown
    570
    thanks at least now I know the pump, pressure sensor and the injectors are ok thanks for the help everyone.
  1. Beaver Falls
    By blackfive-o in forum Meets & Events
    Last Post: 06-12-2012, 05:19 PM
  2. Replies: 12
    Last Post: 06-11-2011, 09:08 AM
  3. Newton Falls Oh rod run?
    By bgblockelcamino in forum Meets & Events
    Last Post: 09-27-2010, 07:59 AM
  4. Down hill at full Throttle!
    Last Post: 03-24-2009, 07:45 AM
  5. Flat Out
    Last Post: 03-05-2008, 09:11 PM
