Results 1 to 20 of 28
Thread: Talon FINALLY dyno'd!
    First off big thanks to TPGtuning for the dyno time, tuning, and hlp with the alternator and crank pulley stuff.
    I'm on my phone still so I'll post more in a couple hours about what happened. Car I fine so don't worry.
    I'll post the dyno link later when I get home but here are the #s
    642.7whp
    495.5ft/lbs
    Stock ignition, no spray, no knock. we would have gone further but my boost controller only let us go to 36psi.
    I have an ARC-2 on order already and we'll be back to try and break 700whp off spray with I.
    It's very laggy so from a roll and short shifts its very mild but you look down and you're flying.
    Ok, here is the official results picture.
    Keep in mind a few things I mentioned above, also we had 0 knock counts during any of the pulls and this wsa 36psi, there's a lot more in it.
    Now for the bad:
    Apparently my crank pulley bolts loosened up on the dyno, we took it down the street, made 1 pull and my $300 fluidampr is now a paperweight. I'm glad that's all that happened and it's certainly replaceable but I'd like to thank the guys that were there for helping me out and getting me a new stocker so quickly.
    I need to go over the car this weekend and button a few things up, this turbo is REALLY laggy so next time up we're going to work on getting the spray set up.
    What is really crazy is we made that kind of power on the stock ignition. I'm going to put the Arc2 on, fill the bottle, get a different boost controller and work on breaking 700whp wit it...then hit the 100 shot :)
    All was done with the MAF, far as I know NAte did no tuning using MAP. It was consistant as hell too, we made more power every pull.
    I'm going to take it to PRP Wednesday but i'm going with low expectations - I hope I'm surprised.
    710whp/520wtq 9.95@145
    awesome!
    mustang aficionado SVTGT's Avatar
    176
    lol Nate has alot of tuning talent. and was a very good instructor while i was at wyotech. great guy to work with. and he will be tuning my modfox and my Sti
    1988 GT "SVTGT" Terminator Fox
    2003 Cobra SVTGT donor. (sad bare chassis)
    1990 LXC 4cyl. (turbo 2.3 in progress)
    2004 World Rally Blue STI (Daily Driver)
    1991 5.0 Auto Notch
    1986 notch(retired SCCA car)
    From what I saw he didn't spend a whole lot of time actually doing any "tuning" He set up the tune, realized cam timing needed played with, and was like - crank the boost....haha.
    It just kept making power each psi we gave it.
    176
    yup thats how he roles. especially with the mitsu's his bread and butter
    1991 5.0 Auto Notch
    Only one question...........what does it run the 1/4 mile in?
    2,103
    Quote Originally Posted by Bluemeanietsi View Post
    Guess we'll see after wednesday. Nice numbers!
    03 Cobra=slow show car...
    13 F-150 Limited
    Not happening now, something decided to cut my timing belt in half down the middle today on the way to my g/fs house. Have another one on order but won't have it this week most likely.
    LowHill
    2,679
    Nice #'s
    Impressive!! Must be a hoot to drive!!
    Damn that is impressive! Keep us updated as to how it works at the track and once you get to putting the spray on!
    BTW-Where is TPG tuning?
    2 year update...
    Car made 710whp/520wtq off the bottle, went 9.95@145 last night spraying 75shot for spool.
    Member torqueboxer's Avatar
    white oak, pa
    638
    I would assume you have shep on speed dial for your tranny? Good ##'s i always liked my tsi, all kinds of snow fun.
    Nah, I run a JacksTransmissions trans, best thing I ever bought. I have yet to break anything drivetrain it's made 10passes over 140mph and 2 of them in the 9's.
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    2 year update...
    I was there yesterday and saw your car. It was damn impressive thats for sure.
    15gt
    94gt
    [ame="http://www.youtube.com/watch?v=ndpHMw_9WkM"]YouTube- 9.95@145[/ame]
    JJsAutomotiveRacing.com SoLow's Avatar
    Jun 2007
    White Oak, PA
    957
    great runs last night LITTLE DOG
    R.I.P Frankie
    3,316
    Awesome numbers and track times!! Gotta love that 4g63! :)
    When I first saw the dyno graphs I thought "yea its nice but by the time it spools you have to shift". Glad to see the track times to back up the dyno sheet! Total respect!
    Aug 2008
    State College PA
    2,326
    WOW ......
    Congrats!
    PICS & Dyno
  1. Finally dyno'd the '95 with the AFR 185 comp heads
    By Killercanary in forum Pictures & Videos
    Last Post: 07-06-2010, 04:59 PM
  2. eagle talon tsi awd 3,800$
    By bigmack in forum Ford Vehicles
    Last Post: 04-27-2009, 02:13 PM
  3. Dyno max dyno challenge.
    By shawnsvtcobra in forum Pictures & Videos
    Last Post: 01-12-2009, 08:59 AM
  4. Looking for a head off of a first gen. talon
    By 2001GTTT in forum Ford Parts
    Last Post: 10-06-2007, 02:01 AM
  5. WTB 17in rims for a 95 talon
    By scott5 in forum Ford Parts
    Last Post: 07-07-2007, 08:38 PM
