Results 1 to 1 of 1
Thread: built aod bolt in and go complete kit
    NEWB
    altoona,p.a
    299
    aod setup out of a 92 lx complete 650 hp
    it has a hardened one peice input shaft/a plus servo/ red clutches / modified drum / p.i stallion 9.5 converter 3400 rpm, stock shifter,flex plate, etc it has the lines and harness peices and dip stick as well, it is 650 hp rated..not a manual valve body, it used a switch for the converter lock out...also was told that if you stay wot it will not shift into od until you get out of the pedal...worked flawlessly and was actually amazed with it...it had 2500 miles on it , and still does as it sat in a heated basement for the last 6 months....i feel i have been very honest in this add...800.00 FIRM FIRM FIRM
    i repeat it is an entire bolt in deal..has everything with it
    email me at ruthlessgsx@aol.com or call 814-207-3299
  1. WTB: Built AOD
    By GOBLIN in forum Ford Parts
    Last Post: 01-23-2012, 06:36 PM
  2. Considering sale of built AOD
    By HOTMARK7 in forum Ford Vehicles
    Last Post: 11-04-2010, 04:09 PM
  3. built aod setup
    Last Post: 09-18-2008, 04:14 AM
  4. lots of goodies tfs heads/built aod/nitrous etc
    Last Post: 09-07-2008, 06:28 AM
  5. built AOD
    By George C in forum Ford Vehicles
    Last Post: 06-11-2007, 01:28 PM
