Results 1 to 3 of 3
Thread: Doctor help
    Doctor help
    As you guys know i just moved here from phoenix az, i wanted to know if anyone has a good ortopedics (sp) surgon out in the pittsburgh area. If you do could you give me some info on the doctor, i hurt my knee again and need someone to check it out for me.
    Thanks
    TJ
    Member torqueboxer's Avatar
    white oak, pa
    638
    http://www.gpoa.com/mds/oad.html
    Dr. Ditano....best in the burgh, I know him personally, you wont be dissapointed. If he can reattach a whole hand, a knee is like fixing a loose water pipe...LL
    never stock biminiLX's Avatar
    Beaver
    2,406
    Dr. Stone at UPMC Sports Medicine, but I'm biased :)
