There is a blasting place in houston on the way to the fairgrounds.
He dosent soda blast.
-Barry
Meadowlands Media Blasting?
I believe that is the name of that place.
-Barry
Why does it have to be soda?
Soda blasting won't effect the metal in any way. Where most other blast media's can warp it or take some metal off. The soda blast will only take off the paint. It's cool stuff.
03 Cobra=slow show car...
13 F-150 Limited
I know what soda will do...crushed walnut shells won't work?
I belive its to abrasive, the soda blast will just take the paint off the hood without pitting or damageing the hood its self. I called a place down in Bridgeville today, 6 weeks behind the guy said. So I said Id call him back. Place in Bulter only does commercal jobs, houses etc.
Anyone know anywhere?
On a side note, I GOT THE STANG BACK THIS MORNING!! Whole car is spotless except the flakeing hood!
-Barry
Envirosafe is a media blasting company that used to be ( and might still be ) on Neville Island, about 3 minutes off of route 79. They did my '66 way back when...the undercarriage, engine compartment and interior ( those areas can be grit blasted as that metal won't warp from the heat ), as well as the exterior ( with plastic media, which generates no heat and will not warp the metal ). They also cleaned out the car and primed it all over with the epoxy primer I supplied, so the car wouldn't get any surface rust while it was in the body shop. I think the owner's name was / is George. I'd give them a call. They also blasted my Dad's '57 TBird and many other cars that my Charlie Baranowski ( local restorer ) has restored.
Also - there used to be a place in Monessen ( I think ) called Ricks Custom Polishing or something like that, and I think he did media blasting.
Good luck, and congrats on getting the car back!!
Stupid question as I've never looked into it, but where are you going to be cost wise with stripping a stock hood and having it refinished versus an aftermarket glass hood, or even a very nice one from a salvage yard (scuff and shoot ready)? Seems like a lot of hassel to save a stock hood.
-Barry
Had to put down our Male German shepherd yesterday. This is way harder than people even describe.
Sorry to hear John, we just had ours put down 2 weeks ago and the other one has real bad hips so we will see if he can make it trough the winter. Awesome dogs though.
Sorry to hear your sad news John. Hang in there - your pal isn't hurting anymore.
