Page 406 of 667 FirstFirst ... 306356396404405406407408416456506 ... LastLast
Results 8,101 to 8,120 of 13321
Thread: Completely off topic BS thread!!!
  1. #8101
    fairmont,WV
    1,352
    How do you figure with the right exhaust set up?
    The actual rousch side exhaust caused a buddy's car to loose power. He had a built engine with a pro charger and put down 360 @12#'s of boost. Switch to a normal exhaust which was the only change and went close to 500.
    The side exhaust mufflers actually go in and out on the same side of the muffler which is a good restriction.
    XXX RWHP
    XXX RWTQ
  2. #8102
    Apr 2010
    South Hills
    3,579
    He went from 360 to 500 just by changing the exhaust? That's unbelievable.
    -Barry
  3. #8103
    2,103
    I find all of this to be realllly hard to believe. Lose power because of less back pressure? Maybe a slight amount of torque... But less back pressure is never bad when trying to make power. And I'm not saying anyone is a liar here, but changin a set of mufflers, and changing nothing else on a car is really pushin it saying you gained 140 horsepower.
    03 Cobra=slow show car...
    13 F-150 Limited
  4. #8104
    Apr 2010
    South Hills
    3,579
    This.
    -Barry
  5. #8105
    Springin' It cLockWise's Avatar
    May 2012
    Gibsonia, PA
    925
    Spintech makes an extremely nice side-exit exhaust which my cousin had on his 01 KBGT. He put down 386/419 on the MustangDyno.
    Were you at Tim's Dyno Day last year when KBGT had his car there? He put down some pretty good power with that Kenne Bell
    Agreed!
    Here's a video of the 01KBGT on the Mustang Dyno
    MODS: 1.7L KB (Meth Injection for Intercooler), 10lb Pulley, 90MM Lightning MAF, 3.55 Gears, BBK Long Tubes, BBK X-pipe, Spintech Mufflers, Roush Side Exit Setup, Subframes, QA1 Tub-k, Coil Overs, PP Throttle Body/Plenum, JLT CAI.. I don't think I'm missing anything lol..
    [ame="http://www.youtube.com/watch?v=gdQ-U4vUnf4"]01 GT stang 386/419 wvstreets.co - YouTube[/ame]
  6. #8106
    Mar 2009
    South Hills & Washington
    863
    Say whaaatt?
  7. #8107
    Apr 2010
    South Hills
    3,579
    Roads are shit right now. First day of spring my ass.
    -Barry
  8. #8108
    May 2012
    Gibsonia, PA
    925
    There's nothing going on down here at my house
  9. #8109
    Apr 2010
    South Hills
    3,579
    It was basically a white out, roads covered. Hill going up past sheetz was a bit sketchy. I don't have any weight in the bed of my truck. Stopped at sheetz and filled it up with gas, 60 bucks.
    -Barry
  10. #8110
    May 2012
    Gibsonia, PA
    925
    I'm approx 15 miles south of there, so the weather changes a good bit from that aspect.. 60 bucks, ouch. I need to stop and get gas tomorrow probably.. F'n ridiculous
  11. #8111
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Been up for couple hours.....entire leg aching. Quit taking pain meds a couple days ago. Go today to get cast off, stitches out and new cast. May take a med before I go since I'm sure it will feel wonderful after they take 22 stitches out, re-angle my foot and recast it. Yipee frickin'ha.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
  12. #8112
    Brookline
    2,897
    I think that's BS but ok. lol
    For the same reason a 3" exhaust won't give you the same amount of power as a 2.5" exhaust, depending on how much power you already make. The engine needs some sort of back pressure to work against to make more power, be it marginal. Too much back pressure is bad though, obviously.
  13. #8113
    Jun 2010
    volant, pa 1 hour 10 minutes to summit
    576
    big exhaust is like a big camshaft. both are terrible mistakes unless your making big power
    6.4 litre fox and its all ford
  14. #8114
    Good luck at the doctor's today Dan. I hope your recovery is going as well as possible. I've been more careful on the stairs since you took your spill.
  15. #8115
    Fuwkawee
    5,151
    Damn, is it me or has this place been slow lately?
  16. #8116
    5,822
    it's you
  17. #8117
    fairmont,WV
    1,352
    And a retune......the rousch mufflers don't reduce back pressure. They increase it by the design of the muffler. In and out on the same side means the exhaust gases do a u turn in the muffler.
    And his car was a real rousch car with the stock exhaust until he switch to different mufflers and dumps
    XXX RWHP
    XXX RWTQ
  18. #8118
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Back pressure, meh. Crazy overrated. Pretty hard to put too big of an exhaust on a car. Stock LS1s and Coyotes all over with 1 7/8" headers making power, some guys would make you believe the setup would lose power over stock. BS.
    2014 M235i (wife's)
    1964 Ford F-100
  19. #8119
    I put a tennis ball in my exhaust and gained 200hp.
    backpressure FTW.
    Then I stuck a tennis ball in my intake and picked up 200hp.
    air restriction FTW.
  20. #8120
    May 2012
    Gibsonia, PA
    925
    backpressure FTW.
    Hahaha
    Sent from my ADR6425LVW using Tapatalk 2
  1. New best or other ET thread
    By mustang50lx in forum Drag Racing
    Last Post: 10-10-2011, 01:03 PM
  2. Replies: 26
    Last Post: 08-16-2009, 11:01 AM
  3. The how old are you thread
    By J-rod in forum The Bar
    Last Post: 01-21-2007, 06:28 PM
  4. Topic: Round 1 Qualifying Video Online at NMRA TV
    Last Post: 09-03-2006, 09:18 PM
