this is funny... http://www.foxnews.com/us/2016/05/04...oto-prank.html
poor kid gets triple dog dared to pull his dong out for the picture and now he's charged with 70 counts of indecent exposure.:dong_out:
2019 Colorado ZR2
but- but- what if the picture hurt some poor little kid's fragile little ego forcing him to hide in his safe space every day before retreating to mom's basement?
THINK OF THE CHILDREN!!!!1!1one!!!!!11!!!!11
if anybody doubted this picture at all... see below. The whole axle is supposed to be the diameter of the center section. This is some Bob Myers carnage, but it took me about 450 hours of mowing at 6MPH... not two weekends and a total of 5 miles.
(Before I put the wheel back on), I packed the hole with lube. When I stuffed the spindle (through the wheel), most of the lube came out the hole in front, so I put that lube on my finger and rubbed it on the shaft (of the steering column). Are we not phrasing anymore ???
2019 Colorado ZR2
Started to look for a truck again. Looking to trade in the Explorer. I want a F150 4 door, used. Has to be grey, silver or black and able to tow. For 20k or under lol
-Barry
I had one like that before on a pull behind mower. However the shaft was welded to a structure that wasn't replaceable...I would have had to cut off the old one and buy a piece of 1045 and weld it in....perfectly straight and parallel to the other wheel....seemed like all kind of failure points for me..LOL
Instead my backyard engineering degree came through and i found some bronze bushings at the local hardware store...drilled out the wheel hub to the right OD and tapped bushing into place, cleaned up the shaft by removing the sharp edge on it, added a liberal amount of grease and rolled with it.
Still sucked but alot better and once per year I would need to replace that bushing....but it got me buy until I bought a zero turn....which cut my mowing down from 3 hrs to 1hr 20 min.
...and improved your GPG ( grass per gallon )
The website I ordered the spindle from was a John Deere aftermarket outfit from Indiana. GreeneTractorParts ? or something. anyway, when I clicked on L-series parts on their website, there was a warning in RED... said IF YOU OWN AN L-SERIES MOWER AND YOU STILL HAVE THE ORIGINAL BUSHINGS IN THE FRONT WHEELS, THEY MAY SEIZE AND DESTROY YOUR SPINDLE. YOU SHOULD REPLACE THE BUSHINGS WITH THESE NEW BALL BEARING UNITS.
Well, no sh1t... I don't randomly peruse aftermarket lawn mower websites. LOL.
2019 Colorado ZR2
I have a buddy who needs to rent a little time on an airstrip to tune his tt ls3 turbo syclone truck . Does anyone have a hook up or info on a local airstrip that can be used ? Maybe the Waynesburg one ? Any phone numbers to contact soneone? Thanks . Text me if u can help.
412 651 1920
route 43 between U'town and B'ville... pay $2.05 and drive all day, you won't see another car. LOL.
2019 Colorado ZR2
Ill see what he says bob. Thanks
