Wow, if i didnt visit this site, you guys wouldnt have anything to talk about :P
ANYWAYS,
i wanted to let everyone know, i got the car back from the shop again, they said this time they found the problem for sure, the intake - head gasket (lower intake) was leaking from around the #2 cylinder, so i was like whatever fix it, they also said they found a glitch in the tps around 3/4 throttle so they put a new one on, but it didnt fix it, so they said they traced a ground issue to my map sensor and replaced that. well $809 later, and the same studder/popping problem is still here, im really lost. The shop has had this car for over a month and they aparently cant figure it out. and im out of money due to me only being 18 and ive put over $1000 into this now. Anyways i thought maybe you guys could be of some assistance because it seems like most of you know quite a bit. so heres what has all been changed:
Tps (changed and didnt effect, so put the old 1 back on)
Iac (have put 2-3 on, and nothing changed)
Map sensor (brand new)
O2 Sensors (was and still is throwing an o2 sensor code, i got the code before so i replaced them, it went away, but the shop said its there now?)
Fuel pressure (checked by shop and they said its fine)
Ghetto comp check (fine)
Timed (by myself and by the shop)
Full dizzy (shop said pip signal failure code came up, so they put in a new dizzy, didnt help :/)
Coolant Temp sensor (replaced the one on the heater rail on the left side of intake)
Plug Wires (msd 8.5mms, didnt change so i took back.. lol)
Plugs (changed when problem first started, problem has been doing it with these plugs for about 5 months)
Coil (tried 2 of them)
Ignition control module (shop said they tried and it did nothing
Lower intake gasket replaced and tested (did nothing)
Egr Valve (didnt help, BUT i was told that the vacuum line (yellow) that plugs into the egr valve is not supposed to have vacuum at idle, mine does???)
Theromostat (had a 160 in thought that was problem put a 192 in)
And i think thats about it,
Also the intake air temp sensor (lower intake) was replaced when we did the intake swap, back in november
Also right after we finished the intake swap 2-4 weeks after, is when this problem started to accure, it ran fine then on the way home from work, just that quickly it started to do it....
Any idea on what this could be?
(btw if you forgot the problem is when first starting the car under any kind of throttle (load) it studders (rpms rise slowly) and it pops (sounds like out of the intake) then when the car reaches operating temp (around 200) the car runs very strong and perfectly normal.
Btw, no i am not selling the car to buy a gm product, or selling the car period!![]()
