Results 1 to 11 of 11
Thread: idle problems???
    In a Time Machine
    3,361
    Exclamation idle problems???
    so I installed my bbk cold air intake today, but now the car idles bad. the rpm's go up and down, n if I dont give it gas it will just die? I was trying to clean the one sensor that screws into the intake tube, and bent the sensor, but bent it back. any suggestions, can I get one of those sensors at a local auto parts store?
    Did you check all the clamps to make sure everything is tight? It's simple but you Have to start somewhere. I dont know the exact setup of the 94-95 air inlets, but if thats your iat sensor that was bent than you can get one at a parts store..
    In a Time Machine
    3,361
    ya I did check the clamps, I knew this to be a problem, but I'm pretty sure thats not it, I guessing the sensor, but dont know what it is to fix it
    you hook up your mass air?
    In a Time Machine
    3,361
    yep.
    do you have different injectors and using stock mass air?
    Try replacing that sensor, and clean mass air, tb and check to see if mass air is working
    Petersburg,PA. 16669
    816
    what meter are you using?
    had this trouble before and some meter just don't like piping on the front side of them
    a good example:
    had a 80mm c&L meter and with the filter on the end of it it would idle like a champ.I took the filter off aput put a 3 1/2 chrome elbow pipe on(like the BBK one just bigger and it rolled idle immedialtely.It didn't matter if the pipe had a filter or not.I could take the pipe off and put the filter back on and would stop rolling idle and idle great.All of this while the car was runnnig so I know for a fact it was the pipe
    88 GT...and some boost
    In a Time Machine
    3,361
    I have a stock maf sensor, and injectors, I went out and ran it again and it seemed to idle better after I tryed tightened up the couplings some more. not sure if that was it, but I'm still gonna try to replace the sensor sometime this week
    5,822
    I don't remember what mods you got? Did you disconnect the negative battery cable while you put the cai on? If not, it'll take 3 or 4 driving cycles (car on / off again) before the stock computer makes some adjustments. Or, go out and disconnect it now and let it sit for a few minutes.
    Jan 2008
    Jefferson
    4,674
    x2!^ my buddys did the same thing
    In a Time Machine
    3,361
    alright, I'll have to try that, I thought it was better last night, but today it was doin the same thing so? I'll keep ya updated
  1. problems with idle
    By to50 in forum General Tech
    Last Post: 05-03-2010, 08:23 AM
  2. Crazy idle help
    By 89 vert in forum General Tech
    Last Post: 06-10-2009, 06:55 PM
  3. Fast Idle
    By hunter31 in forum SN95-New Edge
    Last Post: 03-05-2009, 08:32 AM
  4. rough idle
    Last Post: 07-23-2007, 10:48 PM
  5. erratic idle
    By streetracer in forum General Tech
    Last Post: 05-28-2007, 03:07 PM
