Results 1 to 19 of 19
Thread: latemodelresto 5 lug swaps help.....
    whatever it takes stangfever's Avatar
    i b where im at
    674
    anybody ever buy there conversion and what all year wheels will work with this conversion . latemodelrestorations you get everything for only 400 bux .. seems like a great deal .
    TODAY IS THE DAY I MAKE A DIFFERENCE !!!!!
    LowHill
    2,679
    terrible deal. 2 new drums from napa $30, 2 new rotors from advance $60, 2 axles from upullit $30. Rear diff cover gasket and gear oil $15
    State College, PA
    3,552
    Quote Originally Posted by lib88stang View Post
    x2...all the parts needed are much much cheaper gathering them up yourself
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Jan 2008
    Jefferson
    4,674
    What about the front spindles and calibers backing plates pads mounting brackets? How much does that cost?
    Post the link. If u get performance brakes with it. I'd say go for it but idk. I never looked into those kits. Never had 4 lug.
    If you do that, you might as well kiss your wheel selection good bye!!!
    Senior Member 87notch's Avatar
    803
    Quote Originally Posted by 97LaserRed View Post
    You use Lincoln rotors and keep your existing spindles,calipers etc. if you want to do it as inexpensively as possible.
    Jan 2008
    Jefferson
    4,674
    ah! Good idea never thought of that. Is the wheel selection really that different?
    Quote Originally Posted by 87notch View Post
    i b where im at
    674
    if you do what ... what is the best route to go ... i want to put bullets on my car ..
    LowHill
    2,679
    for FORD bullitts you need 94-95 spindles,calipers and rotors and either steeda balljoints or a spacer. 96-04 stuff also works but makes the front a little wider.
    If you buy aftermarket bullitts the hub on the wheel is bigger and you can use the lincoln rotors. The lincoln rotors have a big hub where the wheel bearings go, so if the wheel have a small hub it won't fit. I had ford bullitts and ground the hub down on lincoln rotors to make them work but center didnt fit right so I swapped it out for 95 stuff.
    Yep. With the Lincoln rotors, the hat will not work with the Bullet wheels. Or any other ford wheel for that matter. You would need to run a 1/2" spacer just to get them on then you would be way out in the front end. Basically, the only way to do the 5-lug is to run SN spindles. Then you gotta choose weather you want to maintain the Fox width (94-95) or go 5/16 wider on each side with '96 and up. Then you need the sn brakes as well. Thats a whole nother can of worms. Simple but so many choices!!!!
    Indeed, unless you like Weld wheels :D They fit fine (draglites, prostars, rodlites). The SVO stuff on the front of my car is the same as the lincoln stuff from the spindle out. Wheel selection is a bit of a bitch, and even like aftermarket bullets are hit or miss if you can put the center caps on.
    There are several options for axles (alloy USA, etc) for new fox width 5 lug reasonable. As was said, add the drums from a parts store, then pick your poison up front, either go with the lincoln stuff and suffer with wheels, or do a SN95 swap.
    Bob Myers
    Bob Myers
    Or you can get stupid like I did and do the full Cobra conversion with a 31 spline rear. HAHAHAHAH
    out in the woods
    4,948
    best,cheapest way... did a few this way.
    only thing is good luck on finding 2 axles from a upull it yard. i heard secriest in dawson closed (the upull it side anyway.)
    2003 polaris predator 500
    (wanna ride,just pm me!!!)
    i b where im at
    674
    i think ill find a nice set of 4 lug wheels and skip the conversion
    LowHill
    2,679
    With lincoln rotors you can run waffle ponys, 17 inch split tri bars, 96 Cobras and like Bob said all welds. Also most aftermarket cobra r's, fr 500 and bullitts have the bigger hub for rangers, lincolns etc..
    i b where im at
    674
    cant find any of those wheels, not cheap anyway ... i wanted to run bullets so i could put the 2 inch lips on the rear ..
    Quote Originally Posted by stangfever View Post
    In that case, your car cant be lowered and you have to run a 7/16 spacer on the rear.
    But will you be able to put the center cap on? I did not know there was such a variance between aftermarket manufacturers.
    out in the woods
    4,948
    with these yes the centercap can be used. i ran the 97 gt split 5spoke on my 89 fox and i had to change over to sn95 front setup to run the centercap.
  1. 5 lug rims
    By blk93notch in forum Ford Parts
    Last Post: 11-04-2012, 06:13 PM
  2. ARE wheels....four lug
    By Dan B. in forum Ford Vehicles
    Last Post: 09-07-2012, 09:08 AM
  3. Replies: 7
    Last Post: 04-15-2008, 11:51 PM
  4. 5 lug is done
    By silvernotch in forum Fox-SN95
    Last Post: 04-08-2008, 09:58 AM
  5. going 5 lug
    By silvernotch in forum General Tech
    Last Post: 04-05-2008, 12:56 PM
