Results 1 to 8 of 8
Thread: Someone do me a favor :P
    Selinsgrove, PA
    526
    Yeah, somebody go outside if you have a 5.0 that still has an EGR valve..
    Start the car.. and see if the vacuum line on your EGR Valve, has any kind of vacuum at idle.
    Shut car off, go back inside, and Let me know if it does :D
    Mine does, but i was told it shouldnt..
    Fox/n.
    3,356
    I don't have a 5.0 here but can tell you that if the valve has vacuum drawing on it at idle the EGR will try to open at idle and it will idle like poop if at all. If you put your fingers under the valve and pull up the diaphragm while idling it should stall the car. So the vacuum should do the same thing. It is supposed to only work at part throttle IIRC.
    Mark
    LeMans Blue Z06
    X2 what Mark said. I also don't have a 5,0, but know on a 2.3 it will basically stall it if you push the diaphram at idle. It will open with vacuum.
    The EGR is onlt intended to introduce exhaust back into the intake tract during part throttle conditions for better economy / emisssions. It should be inactive at idle and WOT.
    Remove the line, plug it, then take it for a drive.
    Fort Eustis, VA
    525
    http://www.asashop.org/autoinc/dec97/egr.htm
    It should stall at idle if it is seeing vacuum
    86 Notch New Project
    Selinsgrove, PA
    526
    well its not much vacuum, i dont think its even enough to open the valve, doesnt look like its opening...
    but should it have vacuum at all or not? if it has a little will that still cause it to run like crap?
    Fox/n.
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    Hmm. I'm having a new problem with hanging idle & missing at part-throttle. I wonder if my EGR is bad.
    2015 GTPP
    If yo follow that vaccum line back, it should go to one of the soleniods on the back side of the strut tower, these should only open when they get signal from the ecu, if you have vaccum at the egr at idle, then the soleniod is bad..
    Selinsgrove, PA
    526
    ok well i just drove it with the vacuum line plugged, and when cold it sounded really weird when moving out of the exhaust, like a miss or something, (thats usually when if i get on it, it will hesitate and studder) if i stayed off the throttle about 1/4 it was fine, but at about 1/2 throttle it really studdered/popped, but again at WOT it pulled very hard.
    Usually it pops/studders the whole time when cold. so what do you guys think? the problem isent the EGR?
    Fox/n.
  1. need favor
    By 94REDGT in forum The Bar
    Last Post: 01-25-2012, 05:03 PM
  2. Replies: 15
    Last Post: 01-29-2007, 12:24 AM
  3. Favor requested, PLEASE READ!
    By u1arunit in forum The Bar
    Last Post: 09-30-2006, 08:29 AM
