Results 1 to 11 of 11
Thread: 95 tuning problems
    Sep 2008
    clarion, pa
    28
    95 tuning problems
    OK I'll try to as brief as possible..
    I am running the Anderson Motorsports PMS w/ the Uego 2000 air flow meter.
    The motor spec's
    347
    trickflow box R intake
    Abaco mass air
    75mm TB
    30lb injectors
    RHS 200/64 cast heads
    Comp Cams @.050 lift Intake 224 Exhaust 236 lobe seperation 114.0
    I am running it on pump gas..
    Now for the questions...
    I am getting the typical surging in the motor at idle and going down the road after I let off of the throttle. What is causing this?
    I can not get it to level out under min load. the car starts "bucking" this happens more frequently at lower RPM's, if I run it at 3800RPM and up it still shows up once and while but not as frequently.. the timing is showing up on the computer as jumping from 4 degrees to 35 degrees and will not settle down. this happens at idle and at part throttle. What do I need to look at or change to help with this problem?
    I could keep going on but this is a starting point, I hope someone else can help me try to figure out what is going on.
    In a Time Machine
    3,361
    dont really know about the tuning part of it, but I thought you had to run a 90 mm throttle body with that box r intake?
    Sep 2008
    clarion, pa
    28
    I think that you can put a 90mm tb on it. but I am using the elbow and it is only 75mm so that is why I went with the 75mm tb.
    I also have the upper trickflow track heat intake and a GT40 that has been ported out.. I wasn't sure which one that I wanted to go with so I started out using the box R intake... anybody ever played around with any of these different intake combo's?
    Sep 2008
    clarion, pa
    28
    I am putting a new ignition system on it today and changed the plugs out.. hopefully this will make a difference and help me to get it tunned properly.
    shaler,pa
    1,010
    I would send killercanary name is paul a pm he can maybe help you sort out your problem.
    89 Mustang (stock) DD
    82 Trans Am (not stock)
    98 Audi A4 (not so hurting)
    Sep 2008
    clarion, pa
    28
    I am going to take it to SGS Automotive and let them tune it for me. anybody know anything about these guys?
    They Will Fix You Right Up They Tuned Alot Of Cars Here And Will Be Tuning Mine Again Sometime
    Sep 2008
    clarion, pa
    28
    that's good to hear.. I have been toying around with this thing all summer... I am now to the point that I just want to get someone with some knowledge on the mustangs to tune it for me.
    I second SGS, I've been happily going there since they opened out on a farm in the middle of nowhere.
    I don't know what would cause the timing issue you are experiencing.
    The idle surge is VERY common in 94-95's when a cam swap is performed. Make sure that you don't have vacuum leak anywhere first and foremost. What RPM is you idle set at? Usually a simple bump in idle to 900-1000rpms clears up the surge.
    Sep 2008
    clarion, pa
    28
    with the IAC unplugged I set the idle around 900rpm with it plugged in it is around 1000rpm.. I have checked multiple times for a vacuum leak and come up with nothing. I might take it to a local shop and have them perform a smoke check on the vacuum system just to double check it.. I have no drivability to it, it is either off the throttle or full throttle.
    Sep 2008
    clarion, pa
    28
    I finally got my car back from SGS and it is alot better now. at least it is drivable.. the weather has been bad so I really did not get to run it much but at least it will idle without me keeping my foot on the pedal. I am disappointed with the communication with SGS, but they did make it run better for a price.
  1. Tuning...
    By 92306gt in forum SN95-New Edge
    Last Post: 07-08-2010, 08:10 PM
  2. 94-95 Tuning Help
    By car4887 in forum Fox-SN95
    Last Post: 07-31-2009, 02:21 AM
  3. Tuning
    By 08stangftw in forum Fox-SN95
    Last Post: 07-27-2009, 10:34 AM
  4. 94-95 tuning?
    By 95gts in forum Fox-SN95
    Last Post: 01-08-2009, 06:43 PM
  5. Tuning?
    Last Post: 07-09-2008, 11:00 PM
