Results 1 to 4 of 4
Thread: speedo correction
    Jan 2008
    Jefferson
    4,674
    speedo correction
    anybody know what kind of speedo correction gear I need to get for a v6 t5 with 3.55 gears I think its a Manual 8-Tooth 3.55 Ratio / White 23 Speedo Gear. Im not sure if it that or the 7 tooth?
    on the website it says...
    Manual Transmissions with 7 Tooth Drive Gear
    • 1983-1989 T-5 OEM
    • Pre 1993 T-5 Aftermarket
    • 1996-1998 Cobra T-45 OEM
    • All Tremec Transmissions
    Manual Transmissions with 8 Tooth Drive Gear
    • 1990-1995 T-5 OEM
    • 1996-1998 T-45 OEM Except Cobra
    where does the 94-98 v6 fall into that?
    i think this is right..... its the 8 tooth
    http://www.steeda.com/cgi-steeda/sb/order.cgi
    Jan 2008
    Jefferson
    4,674
    im sorry that doesn't help me. I dont understand that....
    Fort Eustis, VA
    525
    You input your tire size and gear ratio then look for the gear closest to the red number at the top. You are going to want the driven gear its what you can buy and is installed in like 5-10 mins by removing your speedo cable and sensor fro the trans and swapping the gears.
    86 Notch New Project
  1. WTB: bumpsteer correction tie rods
    By somethingclever in forum Ford Parts
    Last Post: 03-19-2012, 03:32 PM
  2. Correction Factors
    Last Post: 07-13-2010, 12:09 PM
  3. Which speedo gear??
    Last Post: 04-16-2010, 10:32 PM
  4. speedo gear
    Last Post: 01-26-2009, 10:14 PM
