Results 1 to 11 of 11
Thread: 740rwhp 1995 TT supra
    2,247
    my friend is thinking about either buying a newer body style twin turbo supra with a 6 spdand 740rwhp or doing a swap with that motor into his 87 supra that he had now. I keep telling him that even tho they put out Big hp numbers on dynos they don't do well at the track. (he's into drag racing) I've seen it first hand, a 880rwhp supra that ran mid 11's. Why is this? The guy didn't spin or anything. And i've also heard supras can't normally get out of the 11s. This just baffles me...
    Black
    I'm sure there are plenty out there that can and do run better that what is perceived as the "norm" in that they are all dyno queens and can't run for crap at the track. I think from the limited knowledge I have on them that people get greedy and just want that big HP number and go out and put too large of a turbo on them and that is when you get slow ET's and big spiky peak HP numbers with little usable RPM range. I think a lower HP car with a more aptly suited turbo would be faster than the "normal" peaky ones we see around the net.
    There are fast et supras out there and to be honest that is my favorite car of all time. there are alot of things that go into fast ets, but like what paul stated most get wrapped up into the big hp numbers..
    There was a vid of a girl not too long on here with her supra and it shows in one vid it running 11s i think then i knwo there is a vid where its running a 9
    2,247
    So basically their hp curve spikes then drops off drastically?
    Black
    Quote Originally Posted by Shorty429 View Post
    no, from all teh vids i seen they keep making it throughout all rpms
    2,247
    so why can't most run faster than 11's? Is that a myth?
    Black
    depends on alot of things.. its the same way of asking why cant a mustang or camaro or corvette or anything run 10s
    State College, PA
    3,552
    because A LOT more goes into the times your car runs than your peak hp numbers.
    suspension, tires, track conditions, weather conditions, altitude, the drivers ability, weight,......the list can go on forever.
    also a car that makes 400ft/lbs at 2000rpm and holds that power till its shift point will probably rape a supra that makes 700ft/lbs but doesnt make that power till 9500 rpm.
    a broader torque curve on one car will give better results than one that starts low and climbs all the way till 10k rpm on another car, even if the peak numbers are lower on the car with the broad curve
    2013 Mustang GT
    1999 Contour SVT
    SLOW
    Greensburg
    335
    Combination of a lot of things, like above said, suspension etc etc etc. And as another said, just slapping on a big turbo and making big #'s doesn't always seem as good as it sounds. My car makes over 500 tq at 2200 rpm. Get me off the line a lot quicker at the track as compared to building boost after the launch. I'm betting a lot more people built/use their supras for the street rather and then straight out track. Supras shine on highway rolls, go figure haha. That, however, isnt gonna do dick at the track.
    04 KB Cobra
    2008 Jet Steam Blue Z06
    there was an almost stock one at prp, ok it had a front mount and an auto, it went 11.9 i was impressed
    2,247
    Thanks for the input guys! i think i get it now.
    Even though they can put up impressive numbers, the track realy isn't a place for them because the make their HP/TQ way up high and they take too long to spool up. But they're killers from a roll.
    Correct?
    Black
  1. 89 Toyota Supra 1jz
    Last Post: 04-17-2013, 08:51 PM
  2. Fast Supra
    By GEARHEAD94 in forum The Bar
    Last Post: 02-22-2012, 08:23 PM
  3. White 93 Supra
    By schiavo8241 in forum The Bar
    Last Post: 07-07-2009, 04:01 PM
  4. Somebody At SCS Is Getting A Supra
    By PHFIRENO7783 in forum The Bar
    Last Post: 02-02-2009, 12:11 PM
  5. One bad supra
    By Twin01cobra in forum Pictures & Videos
    Last Post: 08-12-2007, 02:36 PM
