Results 1 to 2 of 2
Thread: PI
    Senior Member ebo 4356's Avatar
    Sep 2008
    California, Pa
    194
    PI
    Guys i really want to do a full pi swap, my friend has built numerous 5.0s and he said he'll do the swap. How hard is the swap, and is it worth it. Also is it safe since my car has 86,000 miles, i want to run maybe a stage 2 comp cam. I know its been asked all the time but i ran a 15.2 at 89mph with 3.73s, after the swap what should i run. Thanks guys
    1997 Mustang GT- Sold
    MGW short shifter, Ford Racing 3.73s, JLT ram air intake, mach 1 chin spoiler, Off-road H pipe, Magnaflow Magnapacks, SCT X3 tuner, Full PI swap, steeda underdrive pulleys, 75mm throttle body, professional
    1999 Mustang Gt- On3performance 70mm single turbo, SCT ba2400 mass air meter, upr tubular k frame, upr front coil overs, 42lb injectors, walbro 255, kenne bell bap, pro 5.0 short shifter, 3.73 gears, Modular Head Shop stage 1 cams, SCT X3 tuner. Waiting on dyno tune!
    Uniontown
    1,792
    Quote Originally Posted by ebo 4356 View Post
    Keep the 3.73's in there or 4.10's depends if ya plan on running nitrous. The job isnt super hard just long. As you need to check your work. And make sure he is careful with that timing cover not to over torqu it and to keep that damn lil rubber gasket on place. Make sure he has a couple rubber bands for the back couple head bolts to hold them up pout of the way when takeing the heads off and reinstalling them. If you buy the kit it comes with well detailed instructions. Good luck and it is worth it.
    Got Smoke?
