Thread: Scott's 88 TC 2.3 turbo 11.94 @ 121.01
    73 2.3 Turbo Pinto map351's Avatar
    Leechburgistain Mainland,Cuba
    1,534
    Arrow Scott's 88 TC 2.3 turbo 11.94 @ 121.01
    "I took Glenn88TC's car to the track lastnight for the first time since I've owned it. I've changed the motor combo since when Glenn had it, but the rest is still the same. It's built just out of parts I had laying around, mostly stock junk.
    Stock shortblock
    Factory head, factory stock sized valves. I ported the head, but it doesn't even have a valve job done to it
    8993 hg with TTY bolts
    25psi
    Stock T5
    Stock 3.55 rear
    27x10.5 Hoosier QTP, old and hard
    GT40 with the small turbine wheel in a .68 T4 housing
    It went 11.94 @ 121.01 with a 1.95 60'. Traction was a big problem. The 1.95 was the best of the night and that was a combo of slipping the clutch and spinning.
    I'm not going to buy new slicks before winter. So, it's going to get some other suspension parts and maybe go fast enough to get kicked out.
    It made as much as 435rwhp on the dyno on Thursday!
    I haven't weighed it yet, but I'm guessing somewhere around 3500 with me in it."
    I guess the SDS is the key to unlocking the power...
    289 slabside cobra
    6S1941
    40 Ford Sedan Delivery < For Sale
    Quote Originally Posted by map351;128493[B
    I guess the SDS is the key to unlocking the power..[/B].
    That, and a GT40 turbo with a "small" T4 housing ;)
    Bob Myers
    Spoon Killer HidalgoGT's Avatar
    Uniontown
    1,792
    Could always use my 28 11.5 et streets if ya want. Need new ones for next year anyhow.
    Got Smoke?
    Mike is quoting from another forum, the car isnt terribly local and is owned by Scott Ressler (he is registered here but hasvent seen him post).
    BTW, that pass was at Cecil County and the tune is by SGS.
    Bob Myers
    wow thats awsome ,i read it on turboford but didn't get all the details
    Member xtremeFB's Avatar
    Sep 2007
    altoona
    30
    got any pics of that turbo
    351w stockcrank,rods,trw pistons,victor heads,
    blowthru,66mm turbo,
    new 383w,76mm turbo
  1. Scott, this is all you.
    By John4cam in forum Pictures & Videos
    Last Post: 12-31-2012, 09:19 PM
  2. Big thanks to Scott!!!
    By V3N0mus in forum Scott Rod Fabrications
    Last Post: 07-08-2010, 10:29 AM
  3. Scott Rod Fab
    By biminiLX in forum Pictures & Videos
    Last Post: 01-05-2010, 02:03 PM
  4. here you go scott
    By 94svtcobra in forum The Bar
    Last Post: 09-08-2009, 08:34 PM
  5. Attn. Scott- found one for ya
    By lib88stang in forum The Bar
    Last Post: 07-29-2007, 12:02 AM
