Results 1 to 6 of 6
Thread: block ?
    In a Time Machine
    3,361
    block ?
    how does the new boss block compare to a dart sportsman block. anyone know the hp amount the boss can handle.
    also what would I need to do to make the boss block 347 stroker compatible because of the short cylinders??
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    I've heard that the Boss block is good to about 1500hp, but I've already read about some people taking it past 2000hp. I personally have a Boss block and am VERY impressed with how it looks. Looks super strong. Ask Tim from Rodeheaver's his opinion, he has dealt with Dart blocks before and has my block in his shop now.(I'm his little brother, lol)
    All stock down to the tires
    355hp n/a
    520hp on nitrous
    I have a dart sportsman block, the reason I chose it was because I wanted to use hydraulic lifters and didn't want to spend the >$400 on the linked retro lifters that would have been needed in the dart iron eagle block. The sportsman block is already setup to accept the stock spyder bar and lifters and it can handle over 1000hp without a problem. My machining cost were minimal as the block needed next to nothing. I got a dart and would do so again without a question. If you search on hardcore50.com you will find plenty of reading on both the boss and dart, and their true end cost and abilities.
    Uniontown, PA
    533
    The BOSS block also accepts the stockspyder bar assembly and lifters. It is also already clearanced for strokers. It is not, however, designed to be used with a stroke greater than 3.4 inches
    355hp n/a
    520hp on nitrous
    In a Time Machine
    3,361
    what would the 3.4 equal to?
    with a 5.4 rod length and a piston with a 1.090, and standard 4.00 bore, it will be a 342ci
  1. 324 Boss Block Big Bore Stroker short block $2,900 O.B.O.
    Last Post: 05-03-2014, 03:19 AM
  2. Replies: 14
    Last Post: 02-22-2014, 12:52 PM
  3. block id help please
    By sweeney1030 in forum General Tech
    Last Post: 04-20-2011, 10:39 PM
  4. WTB - Mild 331/347 short block or long block
    By PaceFever79 in forum Ford Parts
    Last Post: 07-11-2010, 06:05 PM
  5. wtb 351w roller engine, block or pre 74 block
    Last Post: 04-08-2009, 10:27 AM
