Results 1 to 4 of 4
Thread: Speedo Gear?
    Speedo Gear?
    Hey guys, my brother just got a 95 GT and he needs to get a speedo gear for it. Which one does he need for 4.10's? Tire size is stock. Thanks
    Polar Vortex
    6,031
    Its been a while, but I believe its a white, 23 tooth...
    1,220
    This is what I used in my T5 with my 3.73's. Ford doesn't make a 23 tooth gear. I got mine from Chrysler. The Chrysler part number is 1-J3167393. The "1-" could be quantity and may not be part of the part number. It's been awhile and I can't remember.
    Thanks for the help guys. It looks like the 23 tooth is the best bet but... from what I've been reading even that won't be enough gear for 4.10's on a 95. There's basically two options, replace the speedo drive gear with a 7 tooth unit and get a 23 tooth speedo gear or just buy a speedcal box. I've got an old T5 that I can probably steal the drive gear that I need, but I don't know if it's worth tearing the tranny apart to put that in.
  1. 20 tooth speedo gear
    By Dan B. in forum Ford Parts
    Last Post: 06-15-2012, 09:03 AM
  2. Which speedo gear??
    Last Post: 04-16-2010, 10:32 PM
  3. speedo gear
    Last Post: 01-26-2009, 10:14 PM
  4. Low Gear AOD...speedo now off
    By Chris00GT in forum Fox-SN95
    Last Post: 10-11-2007, 12:54 AM
  5. Speedo Gear
    By static-x in forum General Tech
    Last Post: 05-30-2007, 01:09 PM
