2001GTTT: nope, not you lol
LS2GTO: It was a GTO in your color. that color is sick!
Sick numbers and even sicker car!! Besides the obvious, whats all done to it?
07 Silverado
05 R6
That was Jester another cammed brazen orange (431whp), Dak is stuck in Shippensburg until next month.
Headers, Cam, Fast92, Injectors, Ported TB, Underdrive pulley, Electric waterpump, full pedders suspension. If I forgot anything dak say so :D
You guys will see this car around the local cruises and such next season, as Dak got transferred back home to Pittsburgh come next month.
isnt there some extra things you have to do so that the fast intakes fit onto the ls2 in the gto and clear i think was the firewall, i know you have to with the vette..
Kooks 1 3/4" Longtubes
Spintech Catback
HPE S-Cam
Patriot Extreme Springs
Trick Flow Pushrods
ASP Underdrive Pulley
AEM CAI
42lb Injectors
FAST 92
Meziere Electric Water Pump
Ported TB
I think that is most of the HP stuff.
To make the FAST fit a LS2:
1. Relocate the MAP sensor to rear of Intake
2. Power Steering Res Bracket needs moved
3. LS1 Style Rails
4. EV1 Injectors with an EV6 Plug
I did not have to move the PS Bracket as I removed all my EVAP Lines and the Purge valve from the
engine. I vent the charcoal can directly into the atmoshere.
sweet set up...
i knew the injectors did not work cause of the o-ring?
clean install.
where you go to dyno?
Dak's not paying much attention so I will answer for ya...
Keith's Pit Stop in Gettysburg
That is where Jeremy Formato makes tuning trips to every 2 months or so.
Formato is one of the best LSx tuners on the east coast, based in Flordia... but he does tuning trips all up and down the coast... He is usually back to Gettysburg every other month.
I believe he is an ls1tech sponser under Fasterproms.com, I know he is on ls1gto
