This weekend I installed my long tube headers, they do have the fitting for the egr that comes down from the valve behind the throttle body. My old H pipe had a tube for the egr tube that runs up front to a rubber hose that t's off and goes the the smog pump which has been disconnected since i have the car, and the other way goes to the back of the heads. My new X pipe does not have this tube. If i don't use this and block off the tube to the back of the heads will it run OK?
I could weld the tube to my new X pipe and it would work but after seeing this with out all that extra rubber hose it has alot less clutter and looks much neater. THANKS GUYS!!!![]()
