Results 1 to 7 of 7
Thread: s-trim or t-trim vortech
    TELL IT LIKE IT IS crazylou's Avatar
    Nov 2008
    ELIZABETH TWP.
    885
    IS ANY1 ON HERE RUNNING A V1-S TRIM OR V2-SQ TRIM??? DO U LIKE IT OR SHOULD U GOT T-TRIM??? NEED SUM IMPUT 4 WHEN I HAVE
    RNH PERFORMANCE DO MY 331 [86-93 FOXBODY]
    THANX
    Senior Member Killercanary's Avatar
    Altoona, PA
    2,338
    There are guys on here with both, so they should help to give you good feedback, but the answer will lie in what max HP do you wish to make, and how much street driving you do. There is also the newer Si trim too which kind of falls in between the S and T trim that you may want to look into. It seems to be the hot ticket for wicked street cars.
    BTW- GREAT choice in using Rick for your shortblock!
    -Paul
    1995 GT 'vert
    Best times on old 302 combo:
    12.03 at 112.5mph NA
    Best time with 9:1 compression NA dart block 331 setup:
    11.50 at 121mph
    Dyno'd: 415rwhp/410rwtq
    2004 Z16 commemorative edition Z06
    100% stock: 11.9 at 118mph
    I Have An S And Love How It Works With A 331 A Si Or T Might Be The Better Choice For More Power
    Senior Member blkp42e's Avatar
    North Hills
    1,229
    i have a v2 SQ trim. love it
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    To make the most of the T-trim you have to spin it up pretty good. If you don't plan on making 16 lbs. of boost or more than I would jsut stick with the S-trim.
    I've had both so ask me how I know............
    Corvette Z06
    Growing up.............Not everyone does it!
    The Si is an upgraded s trim. I dont think Vortech sells an Si trim. I have a V1 S-trim.Aside from the whine, its a decent blower. Very happy with it. Good power and lots of boost. I have seen 14PSI with mine.
    Member HOTMARK7's Avatar
    BUTLER PA
    148
    Have an S trim on the Lincolns 331 at 14 lbs boost, has one size smaller pulley, and made 475 at wheels through aod at 5800 rpm. You can get 18lbs from an s but it has to have the high speed bearings, this is from a vortech tech. The tech told me that if you spin a t and s trim at the same rpm they will put out almost the same psi, only once you really spin the t will it make more boost at the top end.
  1. FS: Vortech V2 S-trim
    By Viper_ed in forum Ford Vehicles
    Last Post: 05-13-2013, 09:56 PM
  2. Vortech S-Trim or SQ-Trim?
    By 95DropTop in forum The Bar
    Last Post: 01-18-2009, 09:33 PM
  3. FS: Vortech S-trim
    By scott5 in forum Ford Vehicles
    Last Post: 12-22-2008, 02:12 PM
  4. Vortech S-trim
    Last Post: 03-14-2008, 06:45 AM
  5. 86-93 Vortech T-Trim
    By Mark Aubele in forum Ford Vehicles
    Last Post: 08-07-2007, 07:10 PM
