Results 1 to 19 of 19
Thread: Turbo project DONE ,car is running and its nasty
    Crazy Bosnian Slow5.0's Avatar
    Erie , PA
    74
    Well first of all its not Stang its my brothers 96 Probe GT 5 speed
    We worked together on this project for some time now and its all done ,car runs great and its nasty fast even on low boost wich is 12psi (thats what i have tunned so far) goal is run this car at 25psi on pump gas,but that will be in summer 07 because winter is here and i like to tune it on road (i don't belive much on dyno because almost everything is different on dyno)
    On street tires in 3rd get at 30mph tires will go in smoke in no time,this turbo is big but there is no lag ,it spools up in no time and screams at 9000rpms
    Here is list of mods
    Engine:
    Fully balanced and blueprinted engine 2.5L V6 DOHC
    Bored .020 over KLDE Block
    Ballanced stock crank
    Wiseco Pistons/Pauter Rods Combo 8.7 CR
    Ross Performance Piston Rings
    Toga HP Oil Pump
    Pro Topline Thrust Washers
    Toga HP Main & Rod Bearings Combo
    Ported/Polished KLDE Heads
    ARP Head Bolts
    Ported & Polished Intake Manifold
    Throttle Body 67mm
    Interprep 195lbs Valve Springs
    Colt Performance Turbo Cams (INT: 210@.355 lift - 274* advertised duration...EX: 200@.350 lift - 240* advertised duration)
    RR-Racing Racing Underdrive Pulley
    Probe Addiction Header Primaries
    QTP 3" Electric Cutout
    255hp Walbro Fuel Pump
    Modified fuel rails for Nissan 550cc's
    Nissan SRDE20 & RB25DET 550cc's Injectors
    PRD Disty Cap w/external coil & additional coil wire
    MBX Ultimate Dual Feed Aeromotive FPR
    Howe Racing Radiator
    MSD 6A Ignition
    MSD Coil Blaster 3
    NGK ZFR7F11 spark plugs
    Garrett GT35R (Turbine: .68mm w/84 trim, Housing .82AR.....Compressor 82mm w/56trim, Housing .70AR)
    Flex-A-Lite Dual Slimline Fans 210R (pullers)
    NCR Performance Turbo Pipes
    NCR Intercooler Pipes (Powdercoated by EPC)
    NCR 3" downpipe
    NCR 3" Performance Turbo CatBack
    NCR 3" TestPipe
    NCR Silicone Couplers & Clamps for IC piping
    Magnaflow Race Muffler
    Precision 31.5x8x3 Intercooler
    HKS SSQV Blow Off Valve
    GP Sorensen IAT Sensor
    Tial 38mm Wastegate .4 bar
    Snow Performance Stage 2 Kit (WM)
    DEI Turbo Insulation Kits
    PRD Red Wrapped Spark Plug Wires
    SS Braided Oil Lines (Feed -4an, drain -10an)
    SS Braided Water Cooled Lines For Turbo -6an
    RR-Racing Poly Engine Mount Inserts (Front & Rear)
    Outlaw Engineering IM & TB Spacers
    K&N 4" (inlet size) Air Filter
    Tapped Oil Pan
    Polished Valve Covers
    Polished Alternator Housing
    Modified CrossMember
    Spectre Air Filter Breather
    RR-Racing Short Throw Shifter w/ shift stabilizer bushings
    Greddy (MBXmotorsports) Oil Cap
    Drivetrain:
    Goodridge Stainless Steel Clutch Line
    MX3 GS Lighten Flywheel 15lbs
    Red Tranny Saver
    SouthBand DXD-F Clutch (rated up to 685hp)*
    Suspension:
    KYB Front Struts
    Dropzone 1.75" Springs
    Wheels/Tires:
    Exel Speed 17x7 wheels
    BFGoodrich g-Force T/A KDW NT Tires 225/45/17
    Extra 2 SE 15" Wheels w/ BFGoodrich G-Force Drag Radials 225/50/15
    Interior:
    Autometer Phantom 5" Tach Gauge
    Autometer Phantom Boost/Vacuum Gauge
    Autometer Phantom Oil Pressure Gauge
    Autometer Phantom Water Temperature Gauge
    AutoVation Racing Pedals (Turbo Charged Design)
    Carbon Fiber Switch for Launch Control
    Carbon Fiber Switch for Switchable Tables
    Ford Racing Steering Wheel Cover
    Greddy Counter Shift Knob
    Greddy Profec B Boost Spec II Controller
    Green/Blue Reverse Glow Gauges
    JVC CD Player KDS680
    MegaSquirt V3.0 (with lots of features)
    Painted Red Interior Dash pieces
    PLX M-300 Wideband
    SPM black Triple A-Pillar Gauge Pod
    Summit Racing Red Battery Relocation Kit
    Here is short video before i tuned car (had safe tuneand WB was off on laptop, but was right at PLX Device wideband)
    And the end you can see me got dizzy, car was running rich, couldnt get to myself for about 5 minutes lol
    http://www.erietuners.com/videos/ThePunisher.wmv
    Here is some pics after whole setup is done
    Here is some pics of parts we use and some pics during build
    Next things during/after winter will be:
    - Build Tranny with Mazda 323 GTX internals
    - Mickey Thompsons ET Street tires (2 of them) mounted on some superlight rims
    - H&R 15mm wheell spacers
    - either power slotted or cross drilled rotors
    - either hawk or portefied brake pads
    - brake braided lines (all around)
    - Sensei SS hood
    - Toxico Illumina Performance Shocks
    - new front & rear bumper (due to having small cracks on it)
    - rear seat delete (install plywood with black carpet on it)
    - Red Bottle in the middle of that plywood covered with black carpet
    - new carpet - change it from tan to black color
    - Race Cage
    - Probe Addiction Project Headlights
    - DVD Screen 7"
    - either keep stock tan leather seats or buy OBX or Spearco Leather Red Racing Seats
    - Racing Harness
    - Get last Phantom gauges (EGT, fuel pressure)
    - FX Triangles for rear bumper (for car shows)
    - FX Lip for front bumper (for car shows)
    And finally new paint, keep same color (Laser Red - Candy) but paint roof in black color with either blue or brown pearls
    Ernan aka Ernie
    '94 GT Vert
    12.76 @ 105 w/ bad clutch 4050lbs 1.8 60FT
    TW heads,B-31 AFM cam..... MORE
    312HP / 340TQ with safe tune
    "A few" pics of my car
    My "Slow5.0 Compilation" video from the begining
    My "Slow5.0 Dyno Compilation" video
    04 Lincoln Navi
    WTB 94-95 5.0 smog pump
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    WOW! :)
    Very sweet.
    Where did he buy his oil lines?
    mark
    LowHill
    2,679
    Very cool
    Senior Member 87notch's Avatar
    803
    SWEET!!
    Banned. shawnsvtcobra's Avatar
    Altoona,Pennsylvania
    2,016
    Now thats a sweeeet setup, and combo. congrats man.
    Erie , PA
    74
    MegaSquirt V3.0
    Ernan aka Ernie
    '94 GT Vert
    04 Lincoln Navi
  1. 95 Turbo 5.0 Project
    By 95gts in forum Fox-SN95
    Last Post: 10-01-2013, 03:22 PM
  2. My car was running like crap after the drags!!!
    By Chargin2004GT in forum Pictures & Videos
    Last Post: 07-13-2009, 12:51 PM
  3. project "BUDJET REPAIR" Smashed but still running
    By oldfox in forum General Tech
    Last Post: 05-15-2009, 06:55 PM
  4. Video of my car running
    By White5.0 in forum Pictures & Videos
    Last Post: 12-30-2008, 10:45 PM
  5. Car is up and running
    By Twin01cobra in forum The Bar
    Last Post: 08-03-2007, 12:55 AM
