Results 1 to 9 of 9
Thread: Finally swapping on my AFR 185 competition heads...
    Well, I'm finally swapping my new heads on. I have to pickup a fuel line disconnect tool tomorrow and then the intake will be off. I want to do a leak down test before I yank the heads, but as soon as that is done I'll be ready to pull these AFR165's and put my new AFR 185's on. I need to get some shims for my shaft mount rockers as the contact area is too far toward the rocker side of the the valve tip. Here's a few pics of the problem:
    Here's where I'm at right now... headers are unbolted, accessory brackets are undone, valve cover bolts are all out, upper intake is off. All I need to do is pull the fuel lines and lower and then the heads.
    Are you going to make cecil?
    Whatcha gonna do with the 165's?
    Rob- I'm trying man... I'm trying. I have two weeks to get the heads on, order pushrods, and tune it. Its going to be close but I hope to make it.
    Wick- Right now I plan to keep them. So far every piece of my old 302 combo that I have removed from the car I kept which means I have a full H/C/I combo here that put my heavy 'vert into the 12.0's just waiting for a new home. I've really taken a liking to autocross and I hope to buy another 94-95 and put the AFR165's and all of my other old parts on it and make it into an autocross car. This old H/C/I combo I had would be perfect for the autocross as it pulled from idle to 6K with no problems.
    Nice...
    Nice...
    Thanks! The only problem is I don't have the funds for a new car and I have no where to put it. :(
    HAHAHAHHAHAHA I hear ya man. Times are getting tough everywhere. My work is slowing way down too due to the steel making industry moving out of the country. Thank you Mr. Economy!!!!!
    Good luck getting her together bud!
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    If you ever want to get rid of the 165's let me know.
  1. AFR 165 or 185 heads?
    Last Post: 06-20-2011, 08:59 PM
  2. Finally dyno'd the '95 with the AFR 185 comp heads
    By Killercanary in forum Pictures & Videos
    Last Post: 07-06-2010, 04:59 PM
  3. Trick Flow TW heads Vs AFR's???
    By John4cam in forum Fox-SN95
    Last Post: 03-04-2009, 06:29 PM
  4. Price of swapping cams and heads on 2V
    Last Post: 12-16-2008, 04:15 PM
  5. AFR 185 comp heads are on!
    By Killercanary in forum Fox-SN95
    Last Post: 11-13-2008, 11:03 AM
