How in the world do I change this? I cannot find a door.
Thanks! Found it thanks to 87notch and SV1000s
Jaguar S Type, Lincoln LS from 2003
C3789
Replacement interval 15.000 km/10,000 miles or after 12 months
Intervalo de cambio 15.000 km o despues de 1 año
Intervalle de remplacement 15.000 km ou une fois par an
Assembly is the reverse order of operation
Para concluir la instalacion, seguir el orden inverso
Le remontage s’effectue dons l’ordre inverse
Tools needed are a standard screwdriver and a
windshield wiper arm puller.
Open the hood
Remove the windshield wiper arm nut covers.
Remove
the windshield wiper arm retaining nuts, then remove
the wiper arms using a suitable windshield wiper arm
puller. Remove the cowl grille screw covers, screws,
and retainers, then remove the cowl grille. Open the
cabin filter cover and remove the filter.
Install a new cabin filter, ensuring the air marking is
facing in the proper direction.
Close the cabin filter cover and install the cowl grille.
Ensure all the screws and retainers are properly
secured. Position the windshield wiper arms to
the pivots, then install the retaining nuts and close
the covers.
Close the hood.
you're gonna be amazed at how nasty that filter's gonna be!
