Results 1 to 17 of 17
Thread: Twisted Wedge heads with e-cam...what rockers??
    Power Adder
    236
    Well I finnaly decided to buy a set of trick flow CNC track heat heads. The problem I'm having is what ratio of roller rockers to get 1.6 or 1.7's with my e-cam?? My next question is what brand rockers would you go with? I like the Pro magnium's, but I only ever seen a listing for 1.6's. I need some idea's...thanks guys!
    Chris Kauffman
    1988 408LX drag car
    They only make them in a 1.6. Here's a good plact to spend some of that miney I just sent you for those injectors :D:
    http://www.steelcitystangs.com/forum...read.php?t=963
    Power Adder
    236
    Actually the money is going towards the heads
    Chris Kauffman
    1988 408LX drag car
    Somerset Co.
    2,907
    Why the E cam?
    Power Adder
    236
    That's the cam thats in the engine now and it was free :).
    Chris Kauffman
    1988 408LX drag car
    Mr. 331 N8Miller's Avatar
    Dec 2006
    Kingston, PA, USA
    239
    i would opt for the 1.7s, but are we talking stock pistons too? (that would make it similar to the 93 cobras, but with much better heads).
    1986 GT:331, Edelbrock Vic Jr heads, Jay Allen custom cam, TFS R intake, 30# injectors, 75mm t-body, 80mm PRO-M, AFM Powerpipe, BBK 1 3/4 long tubes, BBK X pipe, 4.10s, 5 lug conversion, 99GT rims/Nitto DRs, PBR brakes, Lakewood 50/50s, Moroso rear drag springs, Sub frames, 2.5" cowl, Saleen spoiler
    Power of a low 12 second car, Traction of a high 14 second car!
    Power Adder
    236
    Yep, the pistons are stockers.
    Chris Kauffman
    1988 408LX drag car
    Quote Originally Posted by Chris00GT View Post
    E cam with TFS CNC'd heads? There are many different cam choices out there that would make more power and retain driveablilty. Is this a 302 c.i.d. application?
    Somerset Co.
    2,907
    I used to have a 85 Capri RS with the stock bottom end and a set of ported stock cast heads from power heads, "B" cam 1.7 rockers full mac exhaust and the stock 2.73's in the 7.5 rear. My friend had a 84 GT with a roller motor (90) twisted wedge heads, "F" cam and 1.6 rockers and 3.73's in a 8.8. My car would run 12.7 @115 to his 13.3 @ 106 (we even switched cars and got similar results).
    if those heads have 2.02 or bigger valves you better use 1.6, the 1.7s may cause the valve to hit a piston... the stock piston eyebrows are cut for 1.87 valves
    Power Adder
    236
    I know another cam would be better, but for now the e-cam will be fine for the power limitations of the stock block. Yes it is currently 302ci application with a 150hp shot of nitrous on her. This motor already ran good with AFR 185's her and I'd like to see how the trick flow heads work.
    Chris Kauffman
    1988 408LX drag car
    Power Adder
    236
    Ya I think I'm going to stay with the 1.6's. I've had really good luck with Pro Magniums rr and I'd like to stay with them. The guy I sold my old AFR 185's to, said he still had my old magniums and may trade me them back :)
    Chris Kauffman
    1988 408LX drag car
    LowHill
    2,679
    The B-Cam is a strong cam, but I heard it was no good with nitrous, just somthing i read on another site
    Did you have the pistons flycut when the AFR 185's were employed? I have heard the stock HR cam can provide enough P-V clearance. Altering the valve events, ala custom cam, is also a viable choice for AFR 185 headed 302 oem shortblocks.
    OOTB T.W.'s?
    Power Adder
    236
    That is correct we ran the AFR 185 for over a season on a stock short block with stock pistons, an F cam, and 1.6rr. It was a strong combo that ran great with a 100hp shot of nitrous.
    Chris Kauffman
    1988 408LX drag car
    Correct as in no flycutting needed or correct as in flycutting was necessary?
  1. TFS Twisted Wedge O ringed Heads SBF
    Last Post: 10-13-2012, 09:22 PM
  2. Twisted wedge heads??
    By Josh00 GT in forum SN95-New Edge
    Last Post: 03-25-2011, 10:35 PM
  3. Twisted Wedge Heads for SBF DAMAGED
    Last Post: 10-14-2010, 09:44 PM
  4. Trick Flow Twisted Wedge heads,rockers and pushrods
    Last Post: 06-11-2008, 10:21 PM
  5. Trickflow Twisted Wedge R Heads CNC (Brand New)
    By 1foxbody in forum Ford Vehicles
    Last Post: 05-19-2008, 11:44 AM
